AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Dang! Shipped out within 12 hours! Thanks TEAM SAUCY.
redone17
Cold Spring, NY
What would B.A.L.L.S. be with out a BALLSACK? Nicely played Curtis.
Ford Bronco AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc. A1805F4B-7AF6-4EF5-9690-690EABB7BC84
(apologies for the terrible photo)
redone17
Cold Spring, NY
@EIGHTLUG - am I correct in saying that this is the furthest side position possible with these on the TAP?
Ford Bronco AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc. 2189707C-3D7C-4C4E-8434-4AA2B1411712
redone17
Cold Spring, NY
It will work the same way. The Picatinny slot, without the BALL CUP, reduces the overall distance by 8-10mm which will allow the threads to protrude beyond the nut. Functionally, they work the same. Visually, they are different.
Ok, I read through this thread. It seems like mounting the B.A.L.L.S. on the outer picatinny slots and center are out of the question. Kind of a bummer. I should have realized that. I now wish I went with MONO BALL SLAP for my OCD desire for symmetry.
Do you have a specific length bolt that doesn't protrude when not using the cup?
Correct me if I am wrong, but the standard BALLS will work on the SLAP using the CUP? Mine didn't come with any washers - are those rubber?
WHO WANTS TO TRADE MY TAP FOR YOUR SLAP?
The word play in this thread is beyond fun.
redone17
Cold Spring, NY
Ok, I think I figured out the best case scenario. Just need to locate black bolts that are the correct length.
Really wish I could get the left BALL hanging to the left a bit more.
Ford Bronco AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc. C9D1B263-33D4-4704-8330-FE469CE55CA0
Ford Bronco AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc. CFBCECE9-7CE0-44DB-8D62-53483B88CF2E
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
You can use the 1/4-20 position that the button head is in now. There's four 1/4-20 threaded mount positions on the TAP plus the two pill slots in the rail.
Hellion10
Jerry
Denair Ca.
'19 Audi A7 Prestige, '23 Tundra Capstone, ‘69 C10
Any Idea when 20mm Balls are gonna be shippable? Thx - Jerry
2112
Fox island
F350 GT500’s FGT MACH I Z8
What is the best ball clamp device (iPhone) mount?
mzmanny
VA
Mazda Miata
@EIGHTLUG can you send me a replacement 1/4-20 hex flat head screw and washer for the center section of my BYOD?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Did you email us this week about this, or was that someone else?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
I emailed abo
@EIGHTLUG that was me, maybe you can send them with my templar end plates that should be going out soon?
You're a diverse product customer! BAM and (my favorite) TEMPLAR Wing End Plates. End plates should ship out early this week.
mzmanny
VA
Mazda Miata
@EIGHTLUG My other car is a k-swap Miata with a GT250 wing. You had a few different styles of carbon end plates on your site that I don't see anymore, I must've ordered at the right time. There aren't a bunch of carbon end plate options for that air foil. Order 4745 for your reference!
redone17
Cold Spring, NY
So smart! I wouldn’t have thought to use those mount points. I’ll give that a try! Thanks.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
We're in the process of getting our own waterjet to cut the carbon plates with. Once that is all up and going, we'll make the end plates live again, along with new end plate designs.
