Black Diamond/Big Bend Package Options
TexAg13
TexAg13
Brandon
Greenville, SC
2015 Mercedes-Benz E350
I wrote a long reply yesterday but decided not to post it. Basically the advanced transfer case let's you keep the drivetrain in 4-wheel drive all the time (4A) and the transfer case based on inputs from the stability control computer, automatically engages the front drive to improve traction and vehicle stability.
The standard transfer case requires the driver to engage 4-wheel drive when he wants it. However, the 4-wheel drive should not be used on dry pavement because the drivetrain can bind up when making sharp turns. The Advanced transfer case uses a clutch to allow slip between the rear and front axles. The standard transfer case does not have that capability.
I would think the advanced transfer my case would be a good choice for you as it increases the capability of the system. My H3T has such a system and it's great for everyday use.
Good explanation here, amigo! Thanks for the clarification.
Lakelife36
Ben
Interior of BC
If you do lots of Austin Power turnarounds on sketchy hillsides then the advanced is probably a good investment. You should still be able to turn sharply and get power to both axles without binding.
