- Nedim
- Jan 25, 2022
- 7
- 267
- 151
- Richmond, Virginia
- Camaro SS
- Raptor
The Bronco Raptor will have to make significantly more power to offset its weight gain over the Jeep 392. Can the Bronco at least keep up with the existing F-150 Raptor Truck pound per horsepower ratio?
The Bronco Raptor curb weight is 5,773 lbs, the F-150 Raptor curb weight is 5,969 lbs and the Jeep 392 curb weight is 5,103 lbs.
In order for the Bronco Raptor to have the same lbs/1 HP and lbs/ 1 ft lbs of torque ratio as the F-150 Raptor it needs to have 433 hp and 490 ft lbs of torque.
In order for the Bronco Raptor to have the same lbs/1 HP and lbs/1 ft lbs of torque ratio as the Jeep 392 it needs to have 528 hp and 528 ft lbs of torque.
I don't expect the Bronco Raptor will beat the 392 Jeep weight to power ratio; however, I believe it could at least provide enough power to match the F-150 Raptor weight to power ratio (450 hp and 510 ft lbs of torque lbs) which equals to 433 hp and 490 ft lbs of torque in the Bronco Raptor.
Bronco Raptor 433 hp = F-150 Raptor 450 HP (when comparing weight to power ratio)
Bronco Raptor 490 ft lbs = F-150 Raptor 510 ft lbs (when comparing weight to power ratio)
What do you guys think, will they at least make the Bronco Raptor equal to the F-150 Raptor in the weight to power ratio department? Could they even exceed these numbers?
