- Andrew
- Jul 19, 2021
- 1
- 342
- 706
- El Dorado Hills, CA
- 65 Mustang
- Badlands
Not only are they the exact fit, but they tie maintain the dash speaker connections to the front channel just like the factory plug.Yes, it is an exact fit.
The only difference is that the factory speakers have the connector on the outer rim of the speaker which is on the outside of the speaker mount holes. To install aftermarket speakers, you need to route the adapter leads to behind the speaker mount holes. At the base of the kick panel area is a foam panel that you can easily pass the speaker wires through to get them to your speaker. Some of the speaker adapters my have a hole to pass the wires through. And yes, you will likely need a speaker adapter to convert the 3-bolt pattern of the stock speaker to the 4-bolt pattern of most speakers.
