CyberRox
William
My22COBROX
22 Bronco Badlands
The system needs a sub powered by an amp. Something like an 8 or 10”W3 that can handle pretty much all the mid and lows. The stock system has zero punch. Swapping the 4” speakers in the dash running off the stock head unit is fine but no guts at all still.
The rears are practically turned off. Front 4” speakers with a small sub and amp would give 99% of the masses what they are looking for.
If you want more rear fill make sure to go into settings/audio and check all passengers. It might be set for driver only.
vegetarianbarbarian
Ara
Novato, CA
2021 Ford Bronco 4dr
Any tips on fitting the Hertz 165.3 with the crutch field provided metra plate?
can’t figure out how to attach the speaker to the bracket?
mpeugeot
I had to cut plastic to make it all fit under the factory panels. Fortunately, the plastic was super soft and cut like butter. I know that I modified the factory panels, but don't remember if I had to trim the Metra adapters.
Jbald
Justin
Rockport Tx
2003 Mach 1, 2012 F250
I finished upgrading my factory speaker setup and happy with results. Replaced all of the factory speakers with Kicker 4CS speakers (bass blockers on dash too) and recently the powered 11HS8 sub which by far made the best difference as it was dying for bass! I fabb'd up a sturdy mount behind the driver side cargo trim panel to plumb it up (also made a cutout as well) and wired it through the factory L and R wiring channels up to the kick panel. Soldered all connections. World of difference!
Did you tap into both kick panel speakers? What are the actual color of the wires you taped into LF +blue -gray brown RF +YE/OG -GR/BN
TopWaterHit
Chad
Dallas
22 Bronco Black Diamond 2.7l
Yep, those are the wires I tapped into on both L and R for the sub.
Tsr101010
Scot
2020 Bronco OB sas
Base Bad SAS -with 6 speaker crappy system - Joined the upgrade club - used crutchfields for the initial speaker purchase and went with focals only because of past experiences - the difference was amazing !!!! Quality / crispness was great. If I had one piece of advice just buy the power sub from the start so you don’t have to access the kick plate on the left twice - the fullness added by the sub makes it next level especially for the noises ride. Total time around 4 hours and I am not a DIY guy but for around $700 the difference is definitely worth it.
Bukn Bronco
WI
84 Mustang GT, 94 F-150, 2014 Transit Connect,
Saleen Performance now offers plug and play harnesses for all 6 speakers. No cutting, no splicing. Ordered mine yesterday.
MTmeterguy
Jeremy
Sidney, MT
2007 Ford F-150
as I understand it, the kick panel speakers are wired in with the dash speakers. I feel Like the lower kick panel pair are a little quit compared to the upper dash pair. Does anyone have a creative way to balance these speakers and raise the volume on the kick panel compared to the other four?
This is my biggest complaint so far -- my solution is to go active, I have a Hertz 5 channel amplifier on the way to power replacement Hertz mid-bass in the kick panel and replacement Stereo Integrity dash speakers. Down the road, I plan on purchasing the B/O enclosure and find the best sounding 8" that will fit. By running active, I can adjust each front speaker seperately to sound more balanced.
broncoToBe
Not a Bronco
Can you post what you ended up getting? Looking to upgrade mine soon
kkap
Adrian
Georgia
Stormtrooper 2
Just coming in to say thank you to @BroncRik and everyone who contributed to this thread. I went with 4 x Alpine S40s and a Kicker 11HS8. Sounds absolutely amazing and wasn't too much work. Still have to attach the right side KP speaker to the sub, but for now I'm satisfied.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Do we really need to remove all of the trim pieces to get at the 6.5” speakers? I think the Pickens Party of 5 video showed him just removing the speaker grille.
Anyone know the answer to this if just replacing the kick panel speakers (and not installing an amp or sub)? Would be nice to just pop the grille cover off and nothing else. Thank you.
ejaffe
New Jersey
Audi TT
It’s really not a big deal… very easy to pop off.
