Carbon issues in the making for 3.0L Bronco Raptor engine?
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
Does the current 3.0 for the Raptor have such a set up with the air/oil separator?
I don’t know for sure but Ford says any engine newer than 2018 does not need an after-market a/o separator due to a redesigned PCV system. I’d take that to mean it’s like all of their other eco boost engines that have included factory a/o separators.
Raptor911
Raptor911
Broadlands, VA
Ford Performance actually sells a catch can for v8
Ford Bronco Carbon issues in the making for 3.0L Bronco Raptor engine? 1670866647123
jjack50
Jack
Temple, NH
Yes but that’s something included already on the most of the eco Boost engines.
Ducati1098
2022 Bronco Wildtrak, 2012 Ford Fusion
Only the 4 cylinder ecoboost a have a factory oil separator.
Gramd
Graham
Airdrie, Alberta
2022 Bronco, 66 Chevy ll
Run some water/meth. It’ll clear most of it up. My 6.0L turbo LS car is pretty much steam cleaned because of it
Braptor23_CO
Robert
B6g@1776rwh
2023 Bronco
How is it apples to oranges? Modern gas engines are diesels with spark ignition instead of compression ignition. High pressure injection turbo charging and intercooling are all diesel technology that has been applied to gas engines to make them more efficient and powerful. My point was direct injection is not a bad thing and nobody knows yet if carbon build up is going to be a problem in the raptor.
Diesels burn much more thoroughly than gas, percentage wise.
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
Any results for those running a catch can? I have been checking every 1k to gauge how often to change. I have seen the lethal video and the amount they emptied but I have yet to really experience anything other than a minuscule amount from my catch can. Keep in mind I only have the single side PCV catch can.
I have waited 2k miles for this new check that I will do this weekend.
coachoates
Chad
Georgia
Bronco Raptor
I am getting minimal blow-by in my UPR single side...maybe an ounce (less) every 500 miles. But it is summer (I installed in June), less deposits in summer (I have been told compared to colder months), and I drive normal...put my foot in it once a fill-up or so but normally keep in normal mode, no boost, shifts at 2,000 rpm, and coast every chance I get. 90% of my daily driving is through 35-45 roads with slight terrain changes.
SvgOne
Daniel
AR
2023 Bronco 4dr, 2021 Jeep JLUR Diesel
Carbon build-up on intake valves will be an inherent problem for all DI motors. IMHO, port over DI is the only way to reduce the probability of it happening. Separators and catch cans will help, but it may just take longer for it to happen. Prolonging the inevitable. Just my 2 cents. Does the 2.3L run port over injection like the 2.7L? I am curious.
