Diode Dynamics SS3 Fog Light Kit -vs- Elite Series Fog Lamps, Help Me Decide
ILoveTacos
Eastern Shore Of Maryland
Subaru Outback, Honda Pilot
I have a 2022 OBX with the plastic bumper and it looks like Diode Dynamics makes two yellow fog light options which look nice. I like the combination of white LED headlights with yellow fogs on country roads and in the snow or fog.
Has anyone installed either of these and if so do you like them? They both look simple enough to install although only the Elite Series is plug and play, the others say slight modification is required to mount them.
Did you find oncoming drivers flashing you or are they not overly bright, assuming they are leveled correctly.
I'm looking at the sport in the SS3 Fog lights vs the Elite Series Fog Lights.
https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2021-2022-ford-bronco-w-standard-bumper.html
https://www.diodedynamics.com/elite-series-fog-lamps-for-2021-ford-bronco-pair.html
Vtfakie
Robert
2021 Bronco 4dr Wildtrak, Lux, Leather, Tow
I installed the amber SS3 Max on my '21 standard bumper. It was a big improvement over the factory fogs. I have not had anyone flash me yet, even when they weren't angled down properly.
Installation was easy enough, but a fair amount of grinding with a dremel so that they fit properly with enough space to angle them down appropriately.
Ford Bronco Diode Dynamics SS3 Fog Light Kit -vs- Elite Series Fog Lamps, Help Me Decide PXL_20220326_170727058
Ford Bronco Diode Dynamics SS3 Fog Light Kit -vs- Elite Series Fog Lamps, Help Me Decide PXL_20220212_231818779
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
I have the SS3 Pro amber fogs on my Tacoma and have a set of the same to install on the Bronco. They are great lights that are plenty bright and don’t get flashed from other drivers. I am intrigued by the new fogs, and think those might be my choice with the Capable bumper. The aesthetic looks more OEM than the SS3 shoe horned into the same spot. Projector lenses usually have a very sharp cutoff, making them a good choice for fogs.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
SS3 Pro’s here. Exact same experience with hoggin out material to fit the SS3 body when angled properly. Many cut-test fit-cut-test fit, repeat.
I’ve found the SS3 Pro cutoff to be very soft, yes it’s “legal”, but even at full turn down its glaring to oncoming at distance and have been flashed a handful of times… when you get close to it, it’s not as bad.
I’m going to go to with the Max’s on the next Bronco simply for the harder cutoff, the Elites are probably your easiest and best plug n play option out there if you aren’t a fan of cuttin into your new rig. Don’t mind the rough hole saw on the fog bezel, it’s function>form 😂
BroncoAZ
Mitch
I think “soft” is a good description of the cutoff on the Pro. I read that the Sport were a better cutoff, but I like the output on the Pro so that is what I went with. I hadn’t considered the Max for road use, but if the cutoff is sharper then they would be fine. I have driven by dozens of MA state troopers with the fogs on at night, none have stopped me because of them yet. Here are some pics of the Pros on the Tacoma. Notice the yellow above and below on the garage door, I’m not sure if that is reflected back off the door to the truck to scatter or if it’s the cutoff.
Vtfakie
Robert
This is the best pic I have to show the cutoff on the ss3 max
Ford Bronco Diode Dynamics SS3 Fog Light Kit -vs- Elite Series Fog Lamps, Help Me Decide PXL_20220212_231721811
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Our Elite Series Fog Lamps are right in line with our SS3 Sport regarding performance. However, our ES provides an OEM appearance while our SS3s cater to the user seeking an off-road look.
Measured Lumen Output:
ES 1850 lm vs SS3 1520 lm
Peak Intensity:
ES 10200 cd vs SS3 10600 cd
However, our Elite Series Fog Lamps utilize a custom-engineered patent-pending optic that delivers an extremely sharp cut-off, wide beam pattern, and unique BMW-style color banding.
We'll have a comparison video soon from our media team!
In the meantime, Lightwerkz has a brief video comparison of our Elite Series vs. Stage Series fog light options.
We hope this is helpful!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
If you want a brighter fog, go with the SS3. Especially the Pro or Max. The Elite Series are new and are designed as an OEM replacement to give you something as close to an OEM look as possible with a much brighter (over stock) light output. It's a very crisp/clean cut-off.
If you want that same cut-off but BRIGHTER then the SS3 Pro/Max is for you.
We have a ton of Elite Series fogs coming in to us soon. As one of their largest dealers we pre-ordered these when they were first announced to dealers so customers with orders in our system will have their Elite series orders shipping VERY soon.
We also stock a TON of SS3 Sport/Pro/Max lights here as well.
These are the SS3 Max on our truck (we have a triple fog kit though, and it sounds like you have a plastic bumper so you'd only have 1 pair).
Check out our site and grab a set:
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
Ford Bronco Diode Dynamics SS3 Fog Light Kit -vs- Elite Series Fog Lamps, Help Me Decide Diode4
