Hey, since the standard Bronco Auto Start-Stop disable way via Forscan is not working on Raptor, I started to dig in.
Found this on various F150 Raptor forums, where the problem is the same. Apparently, on Raptor, removing Auto Start-Stop is only possible by disabling the Battery Management System. Then, there are two optional parameters. I’m quoting:
Here is an additional explanation posted by F150 Raptor owner called FLG2Raptor.Auto Start/Stop Disable - by disabling BMS (Battery Management System)
BCM 726-48-02 x0xx xxxx xxxx
FCIM 7A7-01-01 xxxx x0xx xxxx (optional - disables switch)
IPC 720-01-01 xxxx 1xxx xxxx (optional - disables stop/start message center in the trip/fuel IPC menu)
I will proceed and try this next week and will report back, if this works for Bronco Raptors.The BCM Change disables the BMS (Battery Management System). Because BMS is disabled, the A.S.S. (Auto Start/Stop) will NEVER engage regardless of whether the switch is on or off. With BMS disabled, the PCM doesn't know the actual condition of the battery and therefore tells the A.S.S. not to engage because the battery needs to charge.
With the BCM change, even turning the A.S.S. on with the switch the A.S.S. will never engage.
