Downsizing from 35" stock sasquatch tires to 33'' later?
gentlemanbronco
Rick
ford fiesta 5.0
Couldn't find a thread on this and I can't be the only one thinking about future costs owning the bronco. I was wondering, 35's are going to look bad ass and all, but realistically replacing them with more 35's is gonna be a bit pricey and I'm wondering about when the time comes to get new tires, switching to maybe 33's. My question is would this affect anything at all on the bronco like rpms, etc? I figure 33's will be less expensive, a smoother ride, better mpg etc etc.
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
Slightly higher RPM's on the highway, but better city MPG, lower tire cost, less road noise, and better ride quality.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I will probably get a set of 33's for winter tires.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Absolutely fine. The different final drive ratio will affect RPMs compared to the same unit spec'd with 33s from the factory... but not enough that it would effect your enjoyment or experience.
Laminar
Iowa
Cougar
Factory 35s will run about $300 each. The same model in a stock Badlands size 33 would be $243 each, so you'd save about $230 on the set of tires.
If the Bronco is anything like the F-150, you can change your tire size in Forscan to fix your speedo reading for free.
RPM with the 35s at 70mph will be 2045. With 33s and the same gearing it'll be 2144, only 100 more, hardly noticeable.
gentlemanbronco
gentlemanbronco
Rick
ford fiesta 5.0
One of my personal favorite GIFs and movies!
96ExplorerSport
White Plains NY
1996 Explorer Sport
This is relevant to my interests. I just realized the 6'6" clearance in a parking garage I need to use is not going to accomodate sasquatch + roof rack. However I think the difference is too great to make up for it with smaller tires. ☹ oh well.
Corsair
Jacob
San Francisco
Escape
Luckily the roof rack should be easy to take off and be put back on. That’s my plan for when I get mine.
96ExplorerSport
White Plains NY
1996 Explorer Sport
I need to find out if the 6'6" max clearance in this garage is for real, somehow (maybe a rental vehicle?) According to this, even without the rack, a 2dr Sas is just a little too tall.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
It will be interesting to see how it mounts. I can tell you my current rack on my Explorer is not something you would want to take on and off to get in your garage.
Beach_Bum
St. Augustine, FL
#SkinnySquatch - Now, others are starting to catch on. I've mentioned it in the past.
