Factory Fog Light Switch
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
So... does anyone have the part number for the factory wiring harness for the fog lights? :)
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Probably something along the lines of MB3Z-15K867-"X" or M2DZ-15K867-"X" if I had to take a guess at it. The harness's are pretty generic in that they're generally built with the same connections just with varying lengths/anchor points.
The challenging part will be if the connector end that the harness would plug into has the pre-wiring for the fog lights (Pins 7 and 8). I would not be surprised if they are not built in and you had to land them yourself in the BCM connector as well as the ground
I’ll report back one of these days. Haven’t had the chance to pull it. Consensus is the wiring is laid out for fogs even if they are not factory. Hoping it’s in the connector too.
j_anderson
Fort Wayne, IN
www.instagram.com
Im certain this type of “factory modification” will be common when the parts departments are stocked with Bronco pieces. I’m also fairly certain this will be difficult to pull off when Ford barely has parts to fill orders.
PS. Is there a trendy term for adding a factory part to a vehicle that didn’t originally come with that part? There has to be a trendy term.
retrofit
cparksjr
Clayton
Linden, MI
2021 Bronco Badlands, 2020 Ford F250 Tremor
Received my M2D-Z11654-BA:
I plan to hook up the Baja SAE Squadrons to front and eventually find a rear bumper that I like with additional reverse lights for the rear fogs.
If anyone is looking for a M2DZ-11654-BA switch, I first ordered the wrong one from the Ford dealer, so have one to sell $55.00 free shipping in USA.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
Which one are you selling? Single or double fog? I’m interested
cparksjr
Clayton
Linden, MI
It is the B version for double fog. Here is picture.
Ford Bronco Factory Fog Light Switch B
mds5917
New Jersey
Thanks! Think I'm going to try to stick to the single switch version on put the rear lights on one of of the upfitters...great deal though!
webspoke
Stan
Pilot Point, TX
F450, GT350
cparksjr
Clayton
Linden, MI
redone17
Cold Spring, NY
I didn't get to pull the factory switch yet (or locate the fog light wiring near the bumper). But, I did dig into the Fog Light settings in Forscan. Here are some screen shots of default settings with Modular Bumper.
Perhaps someone with Standard Bumper can chime in on what these look like WITH factory Fog Lights installed? I guess some are self-explanatory - but, it would be nice to have them switched to exact factory settings.
Ford Bronco Factory Fog Light Switch Screenshot (12)
Ford Bronco Factory Fog Light Switch Screenshot (13)
Ford Bronco Factory Fog Light Switch Screenshot (14)
Ford Bronco Factory Fog Light Switch Screenshot (15)
Ford Bronco Factory Fog Light Switch Screenshot (16)
jorgem31
Jorge
Tampa
I just placed an order for the recommended OBD adaptor ( Amazon.com: OBDLink EX FORScan OBD Adapter : Automotive ). Amazon is delivering tomorrow between 4-8a so I'll try to figure out the rest in the morning. I have the regular bumper with fogs and basically every other option available on a OBX. I'll post any questions if I cannot figure out how to get the files.
redone17
Cold Spring, NY
j_anderson
Fort Wayne, IN
www.instagram.com
So, tell me more about ”rear fogs”. IS this a Bronco light control switch, if so, which trims use it. If not, how does one go about using rear fogs? enable with forscan but then what? Is wiring already in place? Do you have to tap the BCM and run your own to the back? So.many.questions
redone17
Cold Spring, NY
Still digging, but I’m pretty sure the wiring is in place. My thoughts were for upgraded rear lights in the bumper (I personally haven’t seen an upgraded bumper I like just yet). Presumably they only activate when in reverse and switch is on.
j_anderson
Fort Wayne, IN
www.instagram.com
cool!
I have A buddy who drives a Jeep. He was talking about installing amber fogs in the rear. I guess amber cuts through dust better than white light? Easier for those following behind to see you in dusty trail conditions?
