Factory Fog Light Switch
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
I got it apart but now I just need to see if I can get the old switch out of the Bronco.
Ford Bronco Factory Fog Light Switch 20220303_161232
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
Ok I received my ML3Z-11654-DA. So, what is the easiest way to get the switch out of the Bronco? Also, to swap over the puddle light switch? There are tabs all over this thing.
Pull on that panel underneath the steering wheel...to the left of the steering column
zedster
Las Vegas
Oh, so the switch doesn't just come out with the tabs? You have to pull on the panel?
WuNgUn
Ontario Canada
2 door Squatched
Pry it loose on the left and then pull on it on the right side
Hey, thanks for the pics... Good shot of the alley light control module. 👍🏻
I might just try the by-pass speed hack on it this weekend.
Ford Bronco Factory Fog Light Switch Screenshot_20220304-051118_Edge
Saltlife4shore
Anthony
New Jersey
2021 Big Bend
I have a big bend with factory fogs. But on modular bumper. Here are some picks of the factory wire harness for the fogs. Also what it's plugged into. Hope this helps some.
Ford Bronco Factory Fog Light Switch IMG_20220307_125647
Ford Bronco Factory Fog Light Switch IMG_20220307_125656
Ford Bronco Factory Fog Light Switch IMG_20220307_125740
Ford Bronco Factory Fog Light Switch IMG_20220307_125844
Ford Bronco Factory Fog Light Switch IMG_20220307_130839
Ford Bronco Factory Fog Light Switch IMG_20220307_130329
Ford Bronco Factory Fog Light Switch IMG_20220307_131523
Saltlife4shore
Anthony
New Jersey
2021 Big Bend
Quick question the is the black/green wire a ground? There is 1 yellow/orange wire and 1 brown wire. They both get power when turning on the fog light switch. The black and green does nothing, what's that wire for? Thanks.
TX-Hans
That is the ground (-) wire.
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
What do the blue and green switches do? You can't just post extra switches and not share =P
Saltlife4shore
Anthony
New Jersey
2021 Big Bend
Blue is for A piller spot lights, and Green does nothing yet.
LanCar
Sanford, FL
Could you please tell me what the part number is for that switch, that is the one I need.
Here’s a single fog without puddle lights.....
Take note that it doesn’t have a connector to add the puddle module (at screw driver )
Could you please tell me what the part number is for that switch, that's the one I need?
