nkyhunter
mark
nky villa hills
2022 BRONCO,2021 JL RUBICON,2022F150 TREMOR
how the hell does one unplug the phone charger and usb plug from the bottom of the console, not sure squeeze ,pull apart,lift up or get c4 and blow it up?
tjparisi
TJ
Buffalo
2021 Bronco Badlands 4D 7M
Dumb question, if I push the button should it light up with no trailer connected? Just installed it and don’t have a trailer handy. Wondering if i messed something up.
88to21bronco
Tennessee
2017 Nissan Titan XD
So let me add a stupid question: an "off-the-shelf" one-piece under dash controller won't work like it would in most trucks? Am I understanding this correctly?
MTBrad
Brad
Montana
Dodge Powerwagon
Great question...im in the same boat!
RoverDude
Maryland
2021 Bronco (First Edition)
It should / will not light up without a load connected to it. Using a plug tester (led type) will not work either. I used some alligator clips and a cheap generic tail-light bulb from the autoparts store.
Using a lamp will make the knob light up/glow, and adjusting the knob will dim the lamp (indicting difference in braking voltage/force)
" To test your Tow-Pro Elite brake controller, connect a 5 - 26W bulb or automotive test light (with a bulb in it, not LED type) between the ‘ground’ pin (no. 1) and ‘brake controller output’ pin (no. 2) of your trailer 7 pin plug. "
MTBrad
Brad
Montana
Dodge Powerwagon
Thanks RoverDude! That is a huge help!
BAronco
Detroit
2022 Bronco Big Bend
Jebster, as Mybbackpacker stated the tow package as everything for towing with the seven pin connector except the brake controller and there is a plug to the right of the steering column to plug the Ford (REDARC) brake controller in. No cutting are splicing of wires.
Thanks, was wondering what that plug in was for!
Doccruz1
G
Lumberton, NJ
Gladiator
Installed my controller in preparation to pick up my travel trailer
Hated the recommended location so I put it where it fit perfect
Ford Bronco Factory Trailer Brake Controller installation feedback image0 (14)
jd-ford-hd
Tennessee
‘16 Explorer, ‘13 F150, ‘99 F350, '74 Bronco
The answer is no regarding what you’ve been led to believe. And yes, any brake controller you described will work, plug and play, if you have factory tow package….but brings on another question……WHY..? The Redarc is the greatest thing to happen to electric trailer brakes since….well….since Benjamin Franklin got his socks knocked off.! Well worth the cost.!
Ford Bronco Factory Trailer Brake Controller installation feedback 9E63FE47-FFF7-4CAB-B1B8-053AF6E6CA2F
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
What is the difference between this unit and the one from Ford? When I tried to buy the Ford one I waited forever and then it was cancelled due to being unavailable.
jd-ford-hd
Tennessee
Nothing except the Ford accessory has the "vehicle specific" connector harness in the kit. Either of the Redarc Tow Pro units will work. The "Elite" will accommodate 24 volt and will actuate 3 trailer axles. No need for the Elite in a Bronco..!
https://www.redarcelectronics.com/us/catalog/product_compare/
jd-ford-hd
Tennessee
If your Bronco has the factory installed tow package you only need these two items: see pics.
Ford Bronco Factory Trailer Brake Controller installation feedback BD5E8A1B-603D-42A7-895C-56BCCFC9E5EE
Ford Bronco Factory Trailer Brake Controller installation feedback 6F95F0BD-1E10-4E82-B94E-AA42564C7465
jd-ford-hd
Tennessee
If your Bronco does NOT have factory installed trailer tow, you will need these five (5) items AND add your own wiring, front to rear, for 12v, neg. ground and brakes. The yellow wire is often ignored due to very few people needing back up lights to their trailer.
Ford Bronco Factory Trailer Brake Controller installation feedback 9C4C97F4-DA2A-4133-B644-70A403B5F926
Ford Bronco Factory Trailer Brake Controller installation feedback CE098E9B-AEEC-4E54-9F21-1638CA731E8D
Ford Bronco Factory Trailer Brake Controller installation feedback 6C2AEB44-620E-4053-A460-1F551D949518
Ford Bronco Factory Trailer Brake Controller installation feedback 6B540B6C-C677-4598-A07C-66B914321B94
Ford Bronco Factory Trailer Brake Controller installation feedback AF95B7FF-A5C3-4793-8D44-C253DFC06748
