carrellslake
Oregon
2022 Ford Bronco
On the quest to make the roof quieter for road trips, I've been looking for gaps in the roof seals. I found one that I haven't seen on the forum yet. On each side of the roof near the rear glass, this spot had enough of a gap to see through. I put a little bit of weatherstripping in there and now it's one less place making wind noise on the highway.
Ford Bronco Found another MIC hard top seal leak. Weatherstripping solution 1656266592935
International_George
George
Kirkland, WA
1980 International Scout II
What’s the weatherstripping you used?
carrellslake
carrellslake
Oregon
2022 Ford Bronco
Basic 1/2” thick foam weatherstrip.. Found at any superstore. Squeeze it thin before inserting and it expands to fill the gap. I did the same with the front roof panels where they meet the back roof and it helped a lot.
Duck Brand Self Adhesive Foam Weatherstrip Seal for Extra Large Gaps, 3/4-In x 1/2-In x 10-Ft, 1 Roll, 284426 https://a.co/d/4Tdqog5
Hudman316
Detroit
Really sad that we need to do these fixes. I have a 2 door and the wind noise over 35 is really unacceptable.
It’s the price you pay for a top that has multiple pieces. It will never be completely air tight due to thermal dynamics and physics. It’s also going to be louder no matter if there are air leaks or not. It’s not an aerodynamic vehicle.
Deleted member 21681
Guest
Do you have an “after” picture? Trying to get an idea of what you did.
carrellslake
carrellslake
Oregon
2022 Ford Bronco
I don’t, and it wouldn’t show much anyway. I cut off about 1.5” of 1/2-inch weatherstripping, peeled up the rubber in the red box, and shoved it in there. Now I can’t see light coming through anymore.
Guest
Ok, I see! (Well, you know what I mean.)
Thanks!
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
I guess having driven a noisy 5.9 Cummins truck, a 2011 Jeep with hard or soft top, 2006 Jeep with a soft top, and a 1993 Land Cruiser that has had most of the interior panels removed for the past 15 years makes the 2 door Bronco quite quiet to me :D
BroncoRick
www.youtube.com
I have used this Napa truck bed cap weatherstripping tape (part # 7701763) for many years to diagnose and fix leaks on my Jeep tops. Just another product to try that might help out: https://www.napaonline.com/en/p/BK_7701763
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Switching back and forth from an E Class to the Bronco, I realize how quiet the E can be, but didn't think the noise in the hard top B is of any concern, and more so that the E is exceptionally quiet, which makes it that much more boring.
kbBronco
Kyle
Carrollton, TX
2021 Ford Bronco, 2019 Honda Rebel 300
Doing gods work out here brother! Thank you for this
Lazerus
Sean
Las Vegas, NV
Wrangler JL. Land Rover Discovery Sport
You're having a laugh, right? My JL has a 'multi section' hard top. After 2 years in the desert, still no leaks and no gaps whistling in the wind. And it's been through several Arizona monsoons. Is it louder at high speed than my wife's Land Rover? Sure. But you should never be willing to accept something that shoddy in a vehicle costing as much as a Bronco.
Sorry, but the 'What do you expect from an off road vehicle' crowd pisses me off. I expect reasonable quality! And quality at least at the level of it's stated rival.
sic5pointslow
Jose
Bay Area CA
2014 F250, 3 Mustangs, 2018 Audi, annnnd a Buick
I just accepted the wind noise as normal at this point.
