KR Off-Road bracket relocates front license plate below the steel bumper.
The design of this bracket allows for quick and easy removal when you get to a trail head (to avoid snagging it on the trails). It utilizes 2 of the 3 factory accessory bolts on the HD Modular Steel Bumper.
You gotta check out @HBTFD. This is a very nice solution for whatever bumper type you have. I have a Modular Bumper plate mount bolted to the rock guard under my Standard Bumper.
Recommend the DV8 although they are a bit pricier than the rest, I like that it's angled for better aerodynamics. I'm sure it improves MPG by atleast 0.01 miles.
Another vote for DV8 - but I modified mine and added rivnuts to replace the nut/bolt they provide, and with that needed to add a rubber spacer between the bracket and the skid plate/bumper. Waiting for my custom plate to arrive but the test fit is perfect.
Built right industries FTW. Doesn't hang down low like some of the inferior ones and can be mounted on either side, higher or lower, and has a lot of adjustment room.
