mcinfantry
Lee
Louisiana
Badlands 2 door
So, here is what you do. Ford makes availale the stock module configurations for every vehicle thru here:
https://www.motorcraftservice.com/AsBuilt
Next up...you need a VIN... yours and one for a Bronco with this fancy new steering rack. Turns out, you can find such VIN numbhers on cars.com. Here is what I used...
Wildtrack VIN 1FMEE5DP4NLB05301 not sure if this has the fancy new steering gear. I am guessing not.
Raptor which has this fancy steering rack. VIN 1FMEE5JR9NLA51127.
First Edition 2 door (what you have, right?) 1FMDE5FP0MLA20480
You can now donwload the files and compare. Realizing that Ford does not re-invent the wheel when programming items across platforms,you explore such things as Ranger and F150 sites to get info. It is known that the first 3 digits are thye module as follows:
poertrain controlPCM7E0
image processingIPMA706
gateway moduleGWM716
instrument controlIPC720
battery energy controlBECM723
steering column controlSCCM724
body controlBCM726
audio controlACIM727
power steering controlPSCM730
parking aidPAM736
restraint controlRCM737
voltage qualityDCDC746
radio transceiverRTM751
transmission controlTCU754
anti lockABS760
cruise controlCCM764
occupant classification systemOCSM765
digital signal processing radioDSP783
trailerTRM791
all terrain controlATCM792
front controls interfaceFCIM7A7
heads up displayHUD7B2
side obstacle detection leftSODL7C4
side obstacle detection rightSODR7C6
accesory protocal interfaceAPIM7D0
In addtion, the F-150 guys broke down a lot of stuff here:
Some of the more common features will have the same parameters across platforms, where others will be spcific to the F-150 in that document. A lot of paramter descriptions in the 730 (PSCM) for the F-150 should be same as the Bronco.
So, what you are looking for in teh data from the Ford Service site is anything that starts with 730 that is different in your module vas a Raptor module (it has the rack you want). I have done this for you. You will see that a Wild track is missing 730-05-01 paramters vs the First Edition and Raptor. I do beleive this value is related to a parking distance sensor.
The only difference between a Raptor and a First Edition 2 door is the 023A at then end of paramter 730-03-01. What would I do? I would use forscan to take the original configuration out of your old PSCM and load it into your new rack. Then change the value that is different for the Raptor configuration
wildtrackraptorfirst edition
730-01-01FF010100023C730-01-01FF010100023C730-01-01FF010100023C
730-01-0200020000003C730-01-0200020000003C730-01-0200020000003C
730-01-0300000000003B730-01-0300000000003B730-01-0300000000003B
730-01-0400000000003C730-01-0400000000003C730-01-0400000000003C
730-01-05000000003D730-01-05000000003D730-01-05000000003D
730-02-01FFFFFF000037730-02-01FFFFFF000037730-02-01FFFFFF000037
730-02-02FFFF00000039730-02-02FFFF00000039730-02-02FFFF00000039
730-02-03FF000000003B730-02-03FF000000003B730-02-03FF000000003B
730-02-0400000000003D730-02-0400000000003D730-02-0400000000003D
730-02-05000000003E730-02-05000000003E730-02-05000000003E
730-03-01FF00FFFF0139730-03-01FF00FFFF023A730-03-01FF00FFFF0139
730-03-0200FF0000003B730-03-0200FF0000003B730-03-0200FF0000003B
730-03-0300000000003D730-03-0300000000003D730-03-0300000000003D
730-03-0400000000003E730-03-0400000000003E730-03-0400000000003E
730-03-05000000003F730-03-05000000003F730-03-05000000003F
730-04-01FFFFFFFFFF37730-04-01FFFFFFFFFF37730-04-01FFFFFFFFFF37
730-04-02FFFFFFFFFF38730-04-02FFFFFFFFFF38730-04-02FFFFFFFFFF38
730-04-03FFFFFFFFFF39730-04-03FFFFFFFFFF39730-04-03FFFFFFFFFF39
730-04-04FFFFFFFFFF3A730-04-04FFFFFFFFFF3A730-04-04FFFFFFFFFF3A
730-04-05FFFFFFFFFF3B730-04-05FFFFFFFFFF3B730-04-05FFFFFFFFFF3B
730-04-06FFFFFFFFFF3C730-04-06FFFFFFFFFF3C730-04-06FFFFFFFFFF3C
730-04-07FFFFFFFFFF3D730-04-07FFFFFFFFFF3D730-04-07FFFFFFFFFF3D
730-04-08FFFFFFFFFF3E730-04-08FFFFFFFFFF3E730-04-08FFFFFFFFFF3E
730-04-09FFFFFFFFFF3F730-04-09FFFFFFFFFF3F730-04-09FFFFFFFFFF3F
730-04-10FFFFFFFFFF46730-04-10FFFFFFFFFF46730-04-10FFFFFFFFFF46
730-04-11FFFFFFFFFF47730-04-11FFFFFFFFFF47730-04-11FFFFFFFFFF47
730-04-12FFFFFFFFFF48730-04-12FFFFFFFFFF48730-04-12FFFFFFFFFF48
730-04-13FFFFFFFF4A730-04-13FFFFFFFF4A730-04-13FFFFFFFF4A
730-05-01FFFF3B730-05-01FFFF3B
730-06-0100000000003E730-06-0100000000003E730-06-0100000000003E
730-06-0200000000003F730-06-0200000000003F730-06-0200000000003F
730-06-03000000000040730-06-03000000000040730-06-03000000000040
730-06-04000000000041730-06-04000000000041730-06-04000000000041
730-06-050000000042730-06-050000000042730-06-050000000042
Also, realizing that the Ranger uses the same rack control methodology, that shop manual (which I have) can be used to read how the system works. In short, over CAN, the rack gets vehicle speed info. It then uses info from the torque sensor built into the ste steering colum input to the rack along with the speed data to determine how much assist for the rack motor to give. If you have Lane Keeping System (LKS)and Pull Drift Compensation (PDC), the rack can "move itself". The angle sensor is just that...used to determine how far you have turned the wheel for such things as the lines on the backup camera and to determine if the vehicle is going straight (for the PDC system) etc. As far as "calibrating" the rack, there is NOTHING in the shop manual about that. It just tells the technician to go to the ford service website, enter the vehicle vin, download the file for the module, then uplaod it into the new rack....nothing else needed. Becasue of the links above, you now have a method to pull the paramters you need to put in the rack, just like what a Ford technician would do.
For others watching at home....the racks that were failing where not "stripping the gears" Look at pics of failed racks....the casting where the lash adjuster resides is breaking and popping off. Essentially, during high force conditions, the rack is pressing against the lash adjuster and popping it out of the housing. Once the lash adjuster breaks out, the rack can now flop around inside the housing and loose contact with the pinion gear which would lead one to beleive the gears are "stripped"...which they are not. BroncBuster installed a bushing to relieve load from the lash adjuster, but IMHO, he defeated the function of the lash adjuster. If that bushing is a tight fit, it could effect the lash adjustnment on the rack causing other issues over time. From the photos of the new rack, it is very obvious that the area around the lash adjuster has been re-inforced significantly.
Good luck
Ohhhh I love crazy technical discussions like this
bravo
telenerd
Laramie
Subaru
The big question does the new rack drive and work properly?
ksdon
kansas
body controlBCM726
parking aidPAM736
anti lockABS760
trailerTRM791
Good luck
Maybe we need a bolt on clamp that covers the lash adjuster area from the outside???
CheekyOldMan
Bar Harbor, Maine
2022 Bronco Badlands SAS
body controlBCM726
parking aidPAM736
anti lockABS760
trailerTRM791
Good luck
This makes a lot of assumptions, including that the module's software has not been updated for the new component. Techniques like this might work, and have worked in the past, but might also brick your brand new rack, requiring a re-flash. I would advise against just randomly throwing shit into the configuration without some comparison of the module's software revs / variants first.
JBlanco
Julio
Charlotte NC
2023 Bronco BaseSquatch, 2023 Tesla Y Performance
jalawson
TX
‘22 Bronco, ‘17 F150
body controlBCM726
parking aidPAM736
anti lockABS760
trailerTRM791
Good luck
bravo sir. Thank you! Glad to see some knowledgeable Forscan folks starting to show up here. There an abundance of them on the F150 forum.
Rough Rider
2018 Mustang Convertible
Havent gotten through all the thread yet, but....the 5.2L block is too wide for the Bronco Frame due to the DOHC set up. You wont get it in. The 7.3 with the pushrods is actually a lot smaller than the 5.XL block and fits in the Bronco.
2023 Badlands & 2023 Expedition
@BigMeatsBronco doesn’t let realities like a “frame” or “doesn’t come with a truck bed” get in the way of his build.
Ranbronc
Pa
Early Bronco
Im all for throwing random numbers at it and seeing what sticks, Op keep us posted on how its going.
Ducati1098
Raptor guys been trying to crack these types of mods .. not going to work.
There are far more differences between a regular F150 and an F150 Raptor steering system.
I wouldn’t say that it’s even close to a similar comparison between a hoss 2.0 to 3.0 rack. But who knows. We will see.
Ducati1098
I'm talking from 1 generation raptor to the next generation. Not the standard f 150
Either way. Still sounds way more difficult to go between generations that introduce new steering modes and features as opposed to just changing a larger gear when everything else is the same.
No steering features were changed from a 22 Wildtrak to a 22.5 Wildtrak with 3.0 as far as steering that I know of, so I can’t see the programming being very different at all.
That being said, I’ve never tried changing either one. So I’ll take your word for it.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
body controlBCM726
parking aidPAM736
anti lockABS760
trailerTRM791
Good luck
Thanks for this information, most helpful yet and you are correct! My problem at this point is I think I need to use a newer version of forescan. As I can't get it to read the PSCM data or as built? Additionally I believe the calibration code is different for the WT 3.0?
Edit...I have downloaded forscan newest version and it has some new features, but still won't pull up any PSCM data.
CheekyOldMan
Bar Harbor, Maine
Send the logs to the support guy, he probably needs to add the module numbers to his database. You’ll want a paid license for this kind of support.
