- Nate
- Jul 14, 2020
- 54
- 2,690
- 5,845
- Sac-a-tomatoes
- Bronco, F150
- Black Diamond
I guess I was spoiled wheeling toyotas...
Congrats on being post #1111 LOLI guess I was spoiled wheeling toyotas...
Exodus 4x4 mentioned that they were going to use oil impregnated bronze bushings or similar in the production rack a while back, but that's the first pic I've seen of them. Gonna be a pretty stout rack for sure.There's been a lot of talk about bronze bushings, I just don't recall if we knew 74Weld was using them in their rack.
I'm sure most of you guys are following the other thread, but just in case...
Just Wildtrak. Was an option in 22.5, standard on WT in 23 (and up we would assume)I need to flaunt my ignorance some... do all 2023 wildtracks with squatch have the HOSS 3.0 rack?
I tried to build on FORDs website and with squatch it added 3.0 automatically. That being said if so I've got a VIN .
That being said has anyone tried to install on a 2023 Badlands without the vin change? Just wondered if they may have just added it across all levels. I might try it after my funds recover from buying the Hutchinson wheels.
Nice choice in wheelsI might try it after my funds recover from buying the Hutchinson wheels.
how you gonna put them 5 lugs on yer Bronco? the wheels are awesome tho...glad to hear you got your VIN, finally.I need to flaunt my ignorance some... do all 2023 wildtracks with squatch have the HOSS 3.0 rack?
most dealers don't have a clue how to do this. the programming is easy now that we have a system in place that works. a few dealers have contacted me for advice or instructions. I predict the ford pro cal tool will be able to do this in the near future.Can the dealer program one of these on-vehicle, on a Wildtrak 3.0, then just transplant it to a different Bronco? I don't want to mess with all of the hacking, I just want it to work.
I just grabbed a stock photo from the web. Most of these go on jeeps and Toyota. They have them hub-centric for bronco as well.how you gonna put them 5 lugs on yer Bronco? the wheels are awesome tho...glad to hear you got your VIN, finally.
Watch the offset, my 18mm offset is to close to the spindle to run 13.5" wide 37s. Those are even closer so you are limiting yourself to 12.5" wide tires.I just grabbed a stock photo from the web. Most of these go on jeeps and Toyota. They have them hub-centric for bronco as well.
What is this "practical" nonsense you espouse?To be honest with the group I think the practical limit is 37s.
