So if I'm getting this right, I could buy a HOSS 3.0 rack, swap motors and be good to go? Or is there an issue with the clock spring or is that because you did the 3.0 programming first and then did this??? It's kinda weird to me that the clock spring would have anything to do with it. If I remember correctly, didn't one of you test the lock to lock on both racks and they were the same.Time to pour some fuel on the fire!
Presenting the one and only HOSS 2.5 Steering Rack brought to you by @NORCALGXP and Hamm's an America's Classic Premium Beer Born in the land of sky blue waters.
Hoss 1.0 Motor bolted to a HOSS 3.0 rack. Fault codes are below and looks like there is a steering position sensor inside the clock spring. I think this is a very important discovery as there are 2 separate clock springs for the bronco. I have a feeling this is related to why HOSS 3.0 the rack works in my bronco and not fancy those fancy broncos. FYI I Plugged the HOSS 2.5 rack into my bronco for testing.
Next phase will be a full install, since discovering the codes are related to the steering wheel clock spring. So at this point if you do a motor swap you may not need to program the rack. This is pretty big as it will allow more flexibility with a trail repair or make your own HOSS 2.5 rack.
Forgive my ignorance on the subject.
