- First Name
- Brian
- Joined
- Jul 18, 2020
- Threads
- 20
- Messages
- 2,727
- Reaction score
- 6,269
- Location
- Wisconsin USA
- Vehicle(s)
- 1990 Bronco eddie bauer
- Your Bronco Model
- Badlands
We are talking about 2 different things. The errors I was talking about were caused by programing a WT vin into my 2.3/MT BL in order to get TO the point of programming the rack. Once fixed, there are no errors. I solved most by simply unplugging my PCM and AWD module...the rest didn't seem to care. Essentially all you need is a BodyCM and a rack...the rest of the vehicle can be unplugged...the order of steps matter tho. Soon as the PCM sees that WT vin it freaks the eff out. You could unplug ABS too I spoze, but I didn't. I'm gonna install my next 3.0 rack in my 2nd MT BL. Maybe what I can do is program it on my original one, then install it in the "new" one? I'm pretty sure Mark has already done that tho!My question then becomes is if you had to "clear up errors" after words. Then could that happen with a pre-programmed one. In other words did Peugeot "get lucky" and not have error codes???
