How come we haven't seen a snorkel yet??
AcesandEights
Ace!
Oregon
DR650
It's for both. It was traditionally marketed as a water crossing must-have, but most that need/use a snorkel find it provides a benefit in especially dusty conditions.
For gas engines, it's a little less effective than diesel, but works to raise the air intake for water crossings. It also allows for cleaner/cooler air.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
I am no expert but isn't the snorkel for water thing kind of a myth? I thought it was for desert running to get clear air into the engine from higher up, away from the dust you kick up.
It must be, with a aprox 33" safe fording depth the electronics will be flooded before you suck water, besides, if it is that deep you will be floating down stream. :)
Coldsmoke
Knuckles
Northern Illinois
Ford F150 Lariat
With all the electronics both in the engine bay and the interior, the last thing I would do is submerge the Bronco more than the Ford specified depth of 33".
I have a jet boat that has similar electronics on the dash to a modern vehicle as well as computer controlled engines and despite them being sealed in waterproof packaging they are still susceptible to moisture and water issues. It's the only regret I have with that boat & it's been a PIA.
IMHO, take the Bronco in deeper water and you'll regret doing so and your bitching about it to Ford will fall on deaf ears since your warranty will be voided. Food for thought.
MadMan4BamaNATL
Ray
Atlanta
It is mostly for dust and sand. However, running through deep water it gives a little more sense of security.
The vehicle is already built to ford water, so a snorkel is extra.
orion
Jeremy
17' F-250, 17' Explorer
You guys worried about electronics need to watch 4WD 24-7 on YouTube. They cross rivers that go over the hood! And no, they don't float, maybe because there's are loaded down pretty good, but I wouldn't be worried about the Bronco floating!
Channel: https://youtube.com/c/4WD247
3Dogs
2016 Escape, 2000 F150
If you put a snorkel on your $50K Bronco, promise me you’ll do this and take a video!
Drttrac
Troy
Mesa, AZ
2010 Range Rover Sport SC Autobiography
Can someone legitimately explain to me what the point of a snorkel is if you don't have the rest of the underneath sealed as well? That's going to be an issue before you ever hydrolock your engine, aside from you personally floating in your seat and all those interior components that are not deisgned for a 'wash out' getting submerged. (I do see getting the intake higher for better air flow, or our dusty conditions here in AZ.)
HotdogThud
mk6 gti, '21 MoarDoor
it's 4wd cred, nothing more. kinda like lights in the wheel wells and angry grilles on a jeep.
GETSCHWIFTY
Rick Sanchez
Parts Unknown
2021 bronco
Because they’re a tacky gimmick that doesn’t help with water fording and most people don’t get their true design and purpose unless you’re in the south west or South Africa or Australia but I digress.
GETSCHWIFTY
Rick Sanchez
Parts Unknown
2021 bronco
yes.
Cable Guy
Kurt
Audi RS7
wilbersk
Sean
2023 Bronco Raptor
You answered your own question in the end of your comment. Lol
