Shotgun I’m customer #1.I have my prototype printed. Just need to pull the console to test fit the thing in the wife’s Bronco.
I'd buy one from you once you verify fitment. I'd like to have a spare plate without a hole just for future.I have my prototype printed. Just need to pull the console to test fit the thing in the wife’s Bronco.
That’s what I was trying to figure out - if it’s faster charging from the actual USB-C port or cig lighter adapter w/USB-C. Good to know. Thanks.Yup. Like if you got a 12v cig lighter type adapter in your console and you plus your phone cable into it… same concept.
No problem. It really just depends on the power source or cig lighter adapter. The factory usb-c isn't going to offer enough power for speed charging but there may be 12v cig power adapters that do. The coolgear power supply I installed in this mod supplies enough power to the MagSafe puck to charge at the full 15w and if you plugged a usb-c to lighting cable into the same port, it would supply enough power to speed charge the iPhone.That’s what I was trying to figure out - if it’s faster charging from the actual USB-C port or cig lighter adapter w/USB-C. Good to know. Thanks.
I believe the power port that is tapped shuts down after 30 mins and remains off until the door is opened again but I’d need to observe to be sureI just did the mod wasn’t that hard only concern is the charger is on 24/7 it seems, could be useful but worrying about battery draw problems down the line might look for a key on 12 volt power source
It definitely turns off, pretty sure it’s one hour though.I believe the power port that is tapped shuts down after 30 mins and remains off until the door is opened again but I’d need to observe to be sure
Thanks!It definitely turns off, pretty sure it’s one hour though.
For those that don’t want to deal with the 3D printing, I found this flush mount. I ordered it along with the other parts listed out by OP. Thanks for the trail map here!Anyone make any progress on a blank plate for the factory wireless craptastic charger? I have all the parts to do this but need the blank……..I really don’t want this to be what makes me dive into 3D printing.
Any update? I’m anxious to do this because the feeling built in charger is worthless lolI have my prototype printed. Just need to pull the console to test fit the thing in the wife’s Bronco.
