I may be giving in.
ronstar
Ron
Illinois
F-150, Jeep JL
I ordered a non sas 2 dr BB. Plan was to replace the tires with 33" AT's, swap the wheels, get the 4.27 axle, And get some kind of small lift - maybe BL shocks and springs.
I really don't need sas, but I'm not sure I'm up for the hassle of all of these mods. I can see myself giving in and changing my order to include sas.
I'm a late July res, so I'll probably see some 2 door sas's around before mine goes to build. Seeing one may put me over the edge.
Curious how others are dealing with this - Pull the trigger on getting a Sas even though you don't need it? Or sticking to your plan to mod it to a "mini sas" level?
Jr87mustang
Josh
Northern Cali
I have a non-sas BD ordered now, but I bounce around daily between adding Sas to it or dropping down to a Sas BB. Deciding on engine is a problem as well. Such is life.
ronstar
ronstar
Ron
Illinois
F-150, Jeep JL
Good to know that others are having similar decisions even after ordering.
Efthreeoh
Hummer H3T
I'm a manual 2-door BD. Plan on upping to 33's on the stock steel wheels when the factory tires wear out and probably add the locking front diff if the aftermarket provides a fully integrated kit (i.e. software update). Not sure Sas is needed where I go off road.
Fly by Nite
Walt
Pa
Sticking with BaseSquatch for now. Aug res.
Maybe MY22 will bring other options such as a miniSquatch or Squatch lite, considering how popular the Squatch option is. Ford's difficulty in fulfilling Squatch orders and it's impact on the fuel economy, could make lighter options a reality.
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
If you’re going to do all that work anyway, I’d just get sas to not deal with the hassle, wrap your upgrades into your monthly payment, and be covered by warranty for sure.
KirchTX
Nissan
Yeah if you’re doing wheels tires shocks and springs definitely go sas.
Personally I’m going BD and either acquiring BL takeoffs or just swapping in new wheels and 33” tires. I like the look of 33s vs 35s.
Granger Ford said they are planning on doing some kind of buy back program if you let them do the aftermarket wheels but no details or promises yet. I’ll go with the stock wheels until options become less murky.
imnewtothis
Haramol
N/A
I decided to go SAS...at the end of the day getting all of that from factory with warranty is huge.
Plus looking at discussions by pros on other B6G threads....the price for what you get out of SAS is really good.
DeltaBravo
Delta
MIKES MOM
Id consider a lower trimmed model before giving up the SAMQUANCH package
Drex
Jake
After adding the 4.27 (and forced advanced transfer case and automatic), you are less then $5000 from Badlands. Partially swapping the suspension, additional lift, tires, gears, etc. You are going to spend more getting to 'almost' Badlands then actually getting one. Hell, if you go Badlands and stay with a manual transmission you will get 4.7 gears, 33" tires you'll be ahead of the game and can pay it off over time.
Edit; was still typing before OP changed their mind
MadMan4BamaNATL
Ray
Atlanta
Are you really talking shocks and springs, or coilovers like the Bronco comes with Sasquatch?
Redoing a suspension along with wheels and tires while paying for the truck is an expensive proposition if the idea was to save money.
If you're not planning to wheel the Bronco, sure, some money can be saved. However, if you plan to get on some dirt, the Sasquatch package is a really good deal for either a high level stage 1 or low level stage 2 kit (stage 2 if Badlands I'm guessing). Squatch is priced very competitively.
TJconvert2.7
New England
I’m still unclear. I thought the FE and WT had SAS stock, and everything else was non SAS, but SAS capable.
But the Badlands has some sort of lift also?
MadMan4BamaNATL
Ray
Atlanta
The "lift" on a Badlands remains unclear on a Squatch. Yes, Squatch is standard on WT and FE.
Badlands suspension has other upgraded bits and the sway bar disconnect. Think the front locker is Badlands as well. Again, Badlands should be considered as at least stage 1.
Mickey21
Mickey
Round Rock, Texas
2021 Ford Bronco Wildtrak (Race Red)
I knew when I waited this long for the truck, that I would NOT settle on anything I wanted to have on it I could have. Hence, I am going in on a truck I intend to always keep the way I WANT it to be and have no regrets. Luckily life is good enough to me to allow for this to be the case, but that took planning as well.
