I have a Badlands non-SAS 4 door with the HOSS 2.0 suspension. I have two questions I'm hoping you will be able to answer.Here's a quick guide to HOSS 1.0/2.0 fitment:
Fitment for HOSS 1.0 Suspension Package
Fitment for HOSS 2.0 Suspension Package
- 2021-UP Ford Bronco Base without Sasquatch Package
- 2021-UP Ford Bronco Big Bend without Sasquatch Package
- 2021-UP Ford Bronco Black Diamond without Sasquatch Package
- 2021-UP Ford Bronco Outer Banks without Sasquatch Package
- 2021-UP Ford Bronco Base with Sasquatch Package
- 2021-UP Ford Bronco Big Bend with Sasquatch Package
- 2021-UP Ford Bronco Black Diamond with Sasquatch Package
- 2021-UP Ford Bronco Outer Banks with Sasquatch Package
- 2021-UP Ford Bronco Badlands (Sasquatch Package is optional equipment, affects wheel/tire fitment. HOSS 2.0 Suspension Package is standard equipment)
- 2021-UP Ford Bronco Wildtrak with HOSS 2.0 Suspension Package (Sasquatch Package is standard equipment, affects wheel/tire fitment. Does not fit Wildtrak with HOSS 3.0)
- 2021 Ford Bronco First Edition (Sasquatch Package is standard equipment, affects wheel/tire fitment)
- 2022 Ford Bronco Everglades (Sasquatch Package is standard equipment, affects wheel/tire fitment)
These shocks will take out much of the bounciness found in HOSS 1.0, and less so in HOSS 2.0. They will make the ride slightly firmer as you go to the higher snap rings. But to me it was almost imperceptible to me during my ~1500 mile road trip to EJS. You could tell there was less body sway in turns and side-winds, but no noticable increase in road harshness. They rode very nicely on-road. Off-road is where they really shined, especially when you put the hammer down.
1. In regards to medium speed compression dampening (traveling on a medium rough dirt road at 20 to 30 mph), would you consider that your EXP shock will provide a firmer or softer ride than the stock Bilstein HOSS 2.0 suspension?
2. Will your shocks come with boots to cover and protect the shock shaft?
Thank you for your help!
