The video on Youtube from awhile back shows that the Bronco's traction control doesn't work well at all. If you plan on going off road you need a rear locker AND winch minimum. The front locker will keep you from needing to winch so much. If it's a mall crawler then you don't need either
The Bronco traction control doesn't work well because the Bronco can't be purchased with traction control. In the video, he turns on Trail Control in the Bronco thinking it is a comparable to the 4Runner Atrac system. Atrac is a 4 wheel traction control system while Trail Control is just a slow speed cruise control system. The Bronco is still running with open diffs.
Instead, Ford offers lockers with the Bronco. Depending on your usage, the Atrac may be fine or even a better choice, but front and rear lockers is the most capable set up.
