GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
How are the CV's? Any noise or clunking?
I installed the 29 spline ones on my First Edition and they clunked, clicked and growled. When I talked to the vendor I got them from he said they were having complaints from a few customers with the same issues. He said the 32 splines were not experiencing the same issue.
I ripped mine back out and I'm shipping them back.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Mine don't make any noise. Did you also regear or replace the FDU with a spicer?
GloNDark
Reno NV
I left the stock front M210 in place and left the stock gearing in there. Just installed the 29 spline Spicer CV's.
I'm pretty happy with it on 37"s with the stock gearing. If I end up doing the Spicer FDU i'm probably going to leave it the stock gearing
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Just trying to get things lined up for my swap. I'm going from a M190 with FAD and no front locker. Sounds like procal tune will take care of everything FAD related, but how about wiring for the front locker?
I plan to use an aux switch for the relay, but wondering if you wire the locker direct to the battery or if it has to tie into the vehicles computer to work correctly. Anyone wire one up that did not have one before the switch?
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
@tomsoffroad76 has a wire pigtail / factory plug kit for this exact reason. Hit them up!
OX1
jackson nj
59 Bird, 70, 74, 78, 79 Broncos, 84 LTD 331 w/Vortech, 86 Capri 5.0 turbo, 14 Stang GT, 17 Fusion Sport
Just curious. What is 32 spline? The diff itself, or one or both sides of the CV's? (or all of it?)
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Just curious. What is 32 spline? The diff itself, or one or both sides of the CV's? (all all of it?)
The inners are 32 spline at the diff. Also the stub axle is 32 spline. The axle bars inside the CV are 35 splined. The wheel end of CV is factory splined into hub.
OX1
jackson nj
Thanks!!
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
I added some swaybar spacers, after centering the sway bar...the OEM swaybar bracket clamp stoppers allows too much sided to side shift. This was allowing my new spicer boots to kiss the end of the upper swaybar link under full droop. Mine had shifted 3/4"to one side....
Ford uses toooo long of a bolt and deep nut on the upper swaybar link...here's pics.
The spacer pulls the threads and new slimmer nut 1/2" back away from. The boot.
Problem solved.
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
Problem solved.
Ford Bronco Installed 5.38s and Spicer Ultimate  44 FDU  and Extreme CVs 32 spline 20230312_181303
(y) I was just looking at that. For us lazy folks, where did you source the spacer?
Bikeric
Tulsa
1984 4Runner (For Sale)
There might be 100 lbs of extra weight on the Bronco from all the extra threads hanging in the air. If I was a few years younger and more energetic I'd be going around the vehicle with a Sawzall and grinder shaving weight like I did in my bike racing days.
kodiakisland
Arkansas
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Yukon has the 5.13s for the M220. Is this the correct kit and all I need (plus gears) for the install?
YK DM220-FORD | Yukon Gear & Axle
Ford Bronco Installed 5.38s and Spicer Ultimate  44 FDU  and Extreme CVs 32 spline 1681864167502
Yukon gears have developed a horrible reputation....I highly suggest spicer instead.
a quick Google search will reveal Yukon gear manufacturers issues and thousands of failures.
Eric L
2020 Explorer ST, 2017 Fusion Sport
Hey does anyone have the Forscan instructions and code to change the gear ratio?
