Installed StickerFab door sill protectors
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
I installed the StickerFab door sill protectors today. They went on good and were easy to reposition if needed. Zero bubbles.
I went with the 3D carbon for maximum durability. For 15 dollars these are a cheap way to protect the edges on the door sills. The 3D carbon matches the diagonal lines and reflectivity of the nearby trim as well.
Ford Bronco Installed StickerFab door sill protectors 20211121_155153
Ford Bronco Installed StickerFab door sill protectors 20211121_155210
Ford Bronco Installed StickerFab door sill protectors 20211121_155225
Ford Bronco Installed StickerFab door sill protectors 20211121_155246
Herbie
Alex
Cleveland OH
2022 Badlands
I bought the same ones from StickerFab along with several accent items, just waiting for my ride.
adampdx
Adam
Portland, OR
2022 Bronco
Is there any actual grip to these? Do they slip when water is present?
BlazinGTO
BlazinGTO
Dustin
MA
My sneaker does grip on it good. I don't know about wet. I avoid using that area to step anyways. When decent frame mount sliders come out, I'll have a step. These are just added paint protection.
They are textured as you can see in the close up pic. But they are a harder type of vinyl. Not stretchy feeling when I installed it. It's decently thick.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
They appear to be quite similar to 3M DINOC. DINOC is basically a thicker, textured, wear resistant vinyl wrap. It will offer better grip than Clear Coated Paint, but don’t expect it to be similar to Skateboard Grip Tape
talbot
Calgary
2dr BL AMB
looks good!
ordered a set for mine last week
BattleBornBronco
Jon
Las Vegas
2021 Bronco Badlands
Applied to my Bronco as well and can plus one this as a great alternative to more expensive sill protectors.
SigSauer226
James
NJ
1965 Ford Mustang Fastback, 2011 Ford Mustang G
I got the gloss black. I had a bunch of bubbles and they really just look like tape installed. The ones you have look much better. I found them difficult to install without bubbles. Used a pin to get most of them out.
They offer no traction only serve as paint protection. I might upgrade for something better in the future but for now they are ok.
I got the BRONCO letter inserts for the dash too. They installed easily and lol great. Very happy with that and they came with extra letters in case of a mishap.
BlazinGTO
BlazinGTO
Dustin
MA
On the website I see they recommend using soapy water to install any of the vinyl except the carbon. If you didn't do that, it would have helped a lot.
I also installed them when it was low 50s temp. A hot day in direct sun could make everything a bit less forgiving.
In person the 3D carbon looks real good. If you switch I think you will be happy. Very easy to stick on good. Follow the video they have. Apply from the center out. It peels off again real easy and is pretty rigid. It doesn't want to flop and fold over and stick to itself like thin tape. Lots of pressure with my fingers working out from the middle and top to bottom. Ending at the bottom corners. The air forces out pretty easy with a snapping sound.
Time will tell how well they hold up and stay stuck on.
codydb19
Cody
Silverado
Ford Bronco Installed StickerFab door sill protectors CB267A3B-EF76-44DF-B605-2809CB1E02E4
Doesn’t really look like it, but I also installed the StickerFab door sill protectors. I went with the clear PPF because I wanted something that wouldn’t be noticeable. First time ever installing any kind of PPF and this was easy and very manageable with a wet install. It’s not as thick as the PPF my dealer installed on the door edges, but it should hold up to shoes being dragged over it. If it needs to be replaced in a few years I would have no qualms going this route again.
StickerFab even quickly replaced my order when USPS absolutely mangled my first order to the point that it had rips when I took it out of the tube.
Ford Bronco Installed StickerFab door sill protectors E9BB9707-A8AA-4910-A62E-A1B03F09BD75
PowPow
PA
2018 Tahoe
ha! I totally didn't realize this till after I installed them! doh.
Drivers side, the lines align (like you have above), passenger side they go in the opposite direction, kinda like an arrow.
Honestly not a big deal and no one will ever notice. Plus I think the 'arrow' looks fine. And at least I did the same direction for front and back door, so at least that's consistent depending on the side you're on. haha.
Jr87mustang
Josh
Northern Cali
This was my exact experience with them as well. They have zero traction, which for a sticker is normal. I got them just as a stop gap until something better comes along and they work ok for that.
bytheway
Brice
Louisville, KY
Jr87mustang
Josh
Northern Cali
broadicustomworks
Hanging Rock, North Carolina
