Installing overhead aux switches after sales?
Status
Not open for further replies.
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
Well why in the heck is it over there? lol. The box i bought was $125, better than the $400+ for same capabilities. Also, I have come too far now lol
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Got that 6 Gang switch kit from amazon. Real easy to mount in the cab, I utilized the Ford Bronco plate screws to mount the supplied mounting bracket under the plate. Seems like much of this truck is accessory ready! Lights will go on soon, they are on back order.
I plan to use the 8 switch version of this. We stock the AuxBeam panels here at 4x4TruckLEDs.com
NewBroncoOwner
Good Ol USA!!!
I think the connector going up is on the passenger side. C206
Connector Viewer - 150
C100AC100BC101C105C106C107C108C109C110C111C112C113C114C119C121C122C123C124C127C134C135C136C137C138C140C149C150C152C155C160C162C163C167C168AC168BC168CC171C175BC175EC177C181C182C183C184C192C197AC197BC200C201C203C205C206C207C209C210C212C216AC216BC217C218AC218BC218DC218EC218GC220AC220BC221C222C226AC226BC228AC228BC229C229AC229BC229CC233C236C240AC240BC240CC240DC248C256C258AC258BC259AC259BC266C278C285C286C289C296C297C300C301C302C305C310AC310BC318AC318CC319C322C322AC322BC322CC326C328BC328CC331C332C334C335C337C339C350C356C360C362C363C364C365C367C381C383C390C391C392C393C394C402AC402BC404C405C406C410C411C413C414C415C416C420C421C424C425C426C429C431C432C435C436C440C445C446C447C450C475C476C505C525C540C567C573C605C606C608C634C644C726C750C828C850C906C907C908C911C930AC930BC930CC930DC963C1016C1019C1021C1026C1033C1035AC1035BC1035CC1041C1047C1052C1062C1068C1073C1074C1077C1087C1100AC1100BC1100CC1100GC1100JC1101C1102C1104AC1104BC1104CC1107C1111C1112C1120C1137C1139C1140C1147C1148C1149C1151C1153C1160C1222C1271C1292C1293C1294AC1294BC1295AC1295BC1322C1323C1331C1365C1366C1367C1369C1370C1400C1401C1415C1416C1427C1428C1429C1430C1431C1445C1446C1450C1463AC1463BC1465C1466C1469C1513C1551BC1551EC1551TC1561C1562C1563C1564C1565C1566C1570C1582C1584C1615C1616C1617AC1617BC1617CC1617DC1617EC1617FC1617GC1621C1625C1627C1631C1632C1642C1643C1647C1648C1649C1655C1663C1674C1682C1689C1690C1702C1741C1748C1751C1766C1767C1792C1795C1836C1837C1840C1841C1842C1843C1844C1845C1846C1847C1848C1854C1895C1896C1901C1902C1903C1904C1905C1906C1915C1991C1992C1993C1994C1995C1996C2010C2010AC2010BC2010CC2039C2040C2091C2092C2122C2195C2235C2253C2254AC2254BC2280AC2280BC2280CC2280DC2280EC2280FC2280GC2280HC2354C2355C2356C2357C2363C2364C2370C2371C2383AC2383BC2383CC2383DC2383EC2383FC2383GC2385AC2385BC2385CC2405C2406AC2406BC2407AC2407BC2420C2421C2431AC2431CCC2431CDC2431CEC2436C2437C2438C2439C2490C2491C2494AC2494BC2494CC2515AC2515BC2515CC2515DC2564C2565C2608C2809C3006C3007C3051C3059C3075C3106C3159C3187C3189C3200C3201C3209C3210C3211C3212C3215C3216C3220C3240C3243C3245C3247C3318C3319C3323C3336C3336AC3336BC3336CC3338AC3338BC3388C3501C3502AC3502BC3522C3558C3559C3697C3698C3734C3825C4029C4046C4049C4099C4213C4223C4226AC4226BC4287C4320C4321C4330C4331C4336C4357C4359C4360C4369C4370C4397AC4397BC4397CC4452AC4452BC4452CC4478C4479C4544C4545C4546C4547C9018C9019C9026C9035C9064C9066C9224C9440AC9440BC9531​
Inline:DescriptionColorHarnessBase Part #Service Pigtail
C206INLINE14401 14335See Below
MALE
Harness
14401
FEMALE
Harness
14335
Check for Terminal Part Numbers
PinCircuitGaugeQualifier
1**
2CBP02 (GN)20
3CAC12 (GY-OG)14
4CMT18 (VT-OG)22
5RMT10 (VT-GN)22
6VMF05 (GY-BU)22
7VMF04 (BN-BU)22
8**
9CLN09 (YE-GN)22
10**
11**
12CMT10 (BU-BN)22
13VLN04 (VT-GY)22
14GD216 (BK-VT)20
15VDB25 (GN-OG)22
16VDB26 (GY-BU)22
17**
18**
19**
20**
1**
2CBP02 (GN)20
3CAC12 (GY-OG)14
4CMT18 (VT-OG)22
5RMT10 (VT-GN)22
6VMF05 (GY-BU)22
7VMF04 (BN-BU)22
8CBBD9 (BN-WH)22
9CLN09 (YE-GN)22
10DMM13 (BK)22
11**
12CMT10 (BU-BN)22
13VLN04 (VT-GY)22
14GD216 (BK-VT)20
14GD216 (BK-VT)22
15VDB25 (GN-OG)22
16VDB26 (GY-BU)22
17**
18**
19RMM13 (BU)22
20VMM13 (YE-GN)22
You can buy the upper harness for one with aux.
For S&Gs I checked the passenger side A pillar for that harness connection, with no luck on the base trim. Thanks for the schematics @flip they are helpful for understanding where harness connections are to be found in the future.
Southern Girl
1974 Bronco/2023 Bronco
When you install, can you do a video? I don't need them now per se, but I ordered and the Bronco I have now isn't my order. I have a few things I would like to add, but no aux switches.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Sure. I may do it today
4x4TruckLEDs.com
Adam
Lindenhurst, NY
NewBroncoOwner
Good Ol USA!!!
***Update to finding out if you have the up fitter harness from the factory;
Ford Bronco Installing overhead aux switches after sales? tempImage8TwByS
This is the Fuse box under the hood, left is the front of the truck. These 3 fuses circled in red are your AUX switches fuse location. In the manual these are marked as 20s (if equipped) but if you have 5s, there are no harness' to install the OEM switches within the cab.
Ford Bronco Installing overhead aux switches after sales? tempImageffWHFE
Canonman11
Tim
Tampa, FL
I would hope there might be some way to get them installed down the road? Not the news everyone was looking for but thanks for the effort. Was this confirmed by Ford?
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
Did your Super Duty switch assembly looked like this?
I tried to do an image search for the part number that @flip posted, but it’s so new, there were no images available. The Super Duty switch assembly showed up during the same search, though, so I’m assuming the two switch assemblies might be similar even though the part numbers and actual dimensions and features are probably different.
First pic is bronco second is 2018 f250
NewBroncoOwner
Good Ol USA!!!
Maybe possible, But I am pretty confident with the previous looking I performed on both of the A pillars and my electrical engineering background, There is no way a 5 amp fuse is capable to handle any aftermarket powered accessories, or a wiring harness. This is why Page 310+ in the owners manual shows a 20 amp if equipped. Having 5 amps on the fuse block seems it is necessary to pass power to other parts of the block, being wired in series.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
So I didn't look around too much but I did not see a harness above my sunglass holder/overhead console.
It's my believe there is a harness that Ford must install at the factory if you get upfitters that goes from the overhead console... SOMEWHERE. I'd hope it maybe goes into the a-pillar area where a plug might be waiting... or perhaps under the dash? Or maybe they have it go all the way into the fuse panel, who knows.
Hopefully one day we can figure out what is needed.
TXArea51
Juan
Lumberton
FORD Bronco Big Bend SAS
I don’t have the aux switches either but do have the wiring on drivers side. My question is can I connect a relay to say to the rear wires add a switch and connect my reverse lights that way. Do I just have to trace those wires out to see if they go back to the quarter panel. This would be way easier than running new harness all the way to back.
TXArea51
Juan
Lumberton
What I found so far wiring diagram wise.
ssolypop
Solomon
Hawaii
Avenger
I don’t understand why anyone would want to install the auxiliary switches after the fact when it is a $195 option. I don’t get it.
My BL is delayed not likely till late 22 or 23 but I can buy and OBX now. I'm interested because it doesn't have Aux so if I can easily add the switches and some other mods then I will get the OBX now and decide on the BL later. My dealer is increasing the markup probably from 2K if I get the OBX now to 5-8K if I buy a BL later. So I gotta make sacrifices and try to build what I want out of an OBX
Raptor911
Raptor911
Broadlands, VA
forget that adm and find another dealer. If after the fact just get something like a Switchpro9100
Status
