Aztec1382
Sam
F350
Did you install them with the preload the kings came with, or did you crank down the collars
If going above 2 inch will you need to change out the uca
the tubular camburg UCA seems like a good deal
fordguru
fordguru
Riverside ca
Gen 2 raptor, 20 expedition max, bronco ba/sas 2.7
I did not change preload, just the way they came
Aztec1382
Sam
F350
Looks good
decummins
Daniel
New Hampshire
2022 Bronco Wildtrak
So I have the same setup but running BFG K02 35x12.5 with 17"+0 offset. I want to move up to 37's.. but curious about how wide your K03's are (e.g. 12.5, 13.5). Can you supply your complete rim and tire specs? Also have you tested for any rub?
CASM920
Gen 1 Raptor, Bronco Badlands
Here are a pic of angles at ride height
Ford Bronco King Shocks DIY install underway UPDATED WITH NEW PICS 15E8342F-3EF2-4786-9577-686FDE2703E9
Your CV and tierod angles look much better than mine. Could you take a look at what spring rate and length you have on your front coils? Mine came with SPR 3-16-550 and after 1000 miles I still have some steep drive angles on the driver side (shorter axle).
Shifts And Grins Fab
Ryan
Gilbert AZ
shiftsandgrinsfabrication.com
2023 Badlands, 2022 Bronco Wildtrak Sas
There are lots of great aftermarket shock manufacturers out there. King is always in the discussion. We are trying to decide who we will work with to compliment out billet and fabricated suspension components.
fordguru
fordguru
Riverside ca
sorry I haven’t been on in a while
i can check for you
