@Snowdogyyz posted a good picture one post down from yours that shows it installed with the factory floor mat.So I have the factory floor mats and there is a rubber saddle-shaped piece that fits over the driveshaft hump. Looks like I will need to remove this to use the cupholder? There is a "lip" on the floor mat that covers the driveshaft hump.
I can send photos if you have not seen this part of the floormat.
We should have some 2 door full length steps available by early next week. We've been waiting for the powder coaters to catch up!Those have been available for a few weeks now. They havent had the 2 door steps available yet,, wondering if the are having a problem with them.. ?
I put my order in a couple days ago and I pick up my bronco from the dealer next week so should work out great.. Ive been reading about the small spots of rust that some purchasers are experiencing with them but I think some maintenance is to be expected. excited nonetheless. Ill be posting here about them for sure.We should have some 2 door full length steps available by early next week. We've been waiting for the powder coaters to catch up!
@Bronco.babeflorida
As promised, our video!
Time will tell@Bronco.babeflorida
Krista in the houseā¦againā¦wonder if this is any clue on where she may be headed! Anyway, I just received this and have 3 restless teens in the back quite often, so I should be a pretty good real world test for how many times the cup holder becomes unseatedā¦hopefully none, and if it does, thereās no liquid in the cup(s)!
Edit: Super easy install. Hardest part was getting the connectors out (4 of them in my application), but OEM floor mats are not a problem. I also purchased @Mabett rear cup holders, and wasnāt a big fan of drilling into the door to get them installed but decided to pull the impact drillās trigger. I am thinking when there are 3 in the back, it may be better to remove the @IAG Performance cup holder.
I mimicked a teenās kicking/shuffling feet, and I am a bit skeptical on that front. Will keep yāall posted there, but thinking a stronger magnet would mitigate this?!
@Bronco.babeflorida
Hi Snowdogyyz and Cfield90,Installed mine today- before the video was out! I have the rubber factory floor mats and it fits snug- but fine. Easy install- pull back of console off, unplug 4 cables, unscrew two screws and use them to fasten the base in the same holes. Re-install back (make sure no fasteners have come off- one of my blue clips came off). Super easy. Nice product!
Good question- I havenāt tried yet. My guess is itās possible to remove the mat, but reinstalling would be difficult as the base sits pretty tight to the floor. Iām guessing youād need to pop the console cover off to put the mat back. But Iām only guessing as Iām out of town and havenāt messed with it since installing it.Hi Snowdogyyz and Cfield90,
How easy is it remove and re-install the OEM rubber floor mat while the base is installed? Doesn't look possible. Do you need to remove the base each time you want to take the floor mat out? Up here in snow country I need to remove the floor mats regularly to remove dirt, salt and water. I just got this but seems like if I install the base I can't remove the floor mat.
Thanks in advance?
It takes less than a few seconds to pull the console trim in order to remove the floor mat. It doesnāt require touching the wiring to do so.Hi Snowdogyyz and Cfield90,
Thanks in advance?
I havenāt tried removing it yet, but I did receive the replacement magnet. It does seem to be a bit more powerful. Time will tellā¦.Hi Snowdogyyz and Cfield90,
Thanks in advance?
