Problems with K02s?
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I have used both KOs and KMs for years, and in recent years, YES, there have been balancing issues. Not all of them, but about 1 out of 5 it seems have a ride quality issue that balancing wont fix. They won't take them back either. I have lost confidence in BFG and the parent company Michellin over this, and have moved on. They were my favorite offroad tire for many years, but now I am done!
kodiakisland
Arkansas
Balancing marks? There are balancing marks? What do they index to?
The shop I used has been around a long time. I assume they know about them.
Those red and/or yellow dots on the tire are there for a reason.
I wouldn’t assume anything.
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
I have a friend that does mods for a car dealership. He too use to use BFG tires only but had balancing issues the past few years. He has since switched to Nitro exclusively and has not bought a BFG tire in at least two years.
Tdecell
Trey
Clinton, MS
2004 F150, 2021 Outer Banks, 2022 Badlands
23,000 on my set of BFG KO2's, no issues at all, still smooth. Wifes Bronco has KO2's also, 36000 miles, no issues
Ozbronco
Ozbronco
Bella Vista
2023 Badlands 4 door, 2.7 litre, cactus grey
So, he went over to the tire buster and had him dismount the tire and rotate it 180 degrees. The balance then only took one 1/2 oz weight.
Does that mean that the tire and wheel were both out of balance and that by rotating it 180 degrees they counterbalanced each other?
Ozbronco
Ozbronco
Bella Vista
I went back and forth on BFG vs Toyo but ended up with BFG because Toyo is discontinuing their C load 315/70s and I didn't want to run into an issue where I had one needing replacement. Toyo still has D load but I was worried about the harshness.
Load rating was also a factor in for me in staying with the K02s.
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
I have a good friend who is the maintenance foreman for my local County Highway Department.
He swears by KO2's. They run them on 15 trucks or so and have had no issues.
E ratings on the 3/4 ton and 1 ton and C ratings on the 1/2 ton trucks.
I've had my Bronco a year and a half and run KO2 C rated tires, I run them at 35 psi cold and really like them.
My 1 ton diesel will need tires soon and I'm going with the KO2's or their BFG replacement.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Ko2 are notorious for bad balance after they wear a bit. I refuse to have them on my vehicles
tobyw
Toby
Washington
2022 4-Door
30's on the trailer, 37's on the Bronco, 39's on the Gladiator... not an ounce of wheel weights among them and all smooth as glass.
Ford Bronco Problems with K02s? 2023-01-30_08-35-27
lapazleo
2022 bronco badlands
I generally like BFG KO2s and hadn't previously heard of any common balancing issues. THAT SAID, I have the OEM KO2s on my Badlands and 3 of the 4 have a shocking number of wheel weights. Like 6-7 ounces of total weights on a single wheel. I counted about 25-27 quarter oz. weights on this wheel (lost track).
I would be more inclined to believe it's the wheels. I transfered mine to black steelies and they required no weights. See my profile pic.
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
Installed 315/70/17 C Load KO2's last Friday. Balanced fine and ride smooth. In my experience when I've had balance issues it was due to aftermarket wheels. I'm running the Everglades OEM wheels.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
+1 for this. My 315 KO2s are great on Everglades wheels. They were a little squirrely during first few hundred miles (manufacturing oils maybe), however have smoother out fine. I'm around 5k miles on them now.
[DELETED MEMBER 27901]
This thread fascinates me because it’s either people who swear by them on their last 15 trucks or guys who never got them to balance from day one. Maybe there’s significant differences lot to lot?
Traction can be a bit subjective so it’s hard to say either way.
Golfsnob
St Augustine
Just an FYI. I was averaging 22.6mpg on the 285/70/17 BFG and when I went to the 315/70/70 I'm now averaging 22.5. Figured it would drop more than that but I'll take it. Yes I adjusted the tire size in Forscan and the speedometer is dead on.
