Valhalla
Valhalla
Chattanooga Tn
Just WOW! I wonder if a knew bolt and nut were used? Is this a one-use item? Super glad you guys were okay!
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
Wondering if I can see the knuckle flaoting around in this vid
That tapping noise, is that from the UCA being loose, I have the same noise and can't seem to figure it out
Valhalla
Valhalla
Chattanooga Tn
Hmm very possibly. I can’t recall what I was hearing there as I was concentrating on the line, I do have some driveline lash that will crunk like that too (but doesn’t sound nearly so loud, at least from inside)
2021FordBronco2
Jo
Nampa, ID
The noise that I have sounds like one of the skid plates flexing so it creaks, I took it to the dealer, they said it was my aftermarket UCAs making the noise but they said everything looked fine, I am now wondering after seeing your post if they are loose and they didn't even check that.
is with a wrench, one is visual. Bolts can stretch and be out of torque, bushings can compress.
This is true. Paint mark is just a quick visual check to tell you the bolt hasn’t backed off.
Which, honestly, for most applications seems like it would be ok. The torque is ~usually~ there to make sure the bolt doesn’t back off in the first place, so paint just tells you it hasn’t moved
There are some places were torque check is for more than to just make sure hold two stay bolted together - but most of the nuts and bolts here are doing just that
userdude
Denton, TX
2023 2dr Badsquatch
I don't see anything in that picture that seems off. Is there a bare bolt somewhere?
CalvinT
Calvin
Phoenix, AZ
Paint is often used in the factory as verification that a fastener has been torqued to final specification. This allows for fast visual inspection down the line. It won't keep a fastener from getting loose.
SierraBronco
One
I guess I look at it as the witness mark is only used as a visual indicator and should be applied after the appropriate torque has been used. If it moves, the connection needs to be looked at. Just a quick way to verify if something has loosened or not. Saved our bacon several times with the aerospace portals when paint marks on the bolts holding the brake brackets on weren’t lined up.
CalvinT
Calvin
Phoenix, AZ
I agree, they can also function as a witness mark if applied properly. But sometimes they cover the entire fitting and you lose that feature.
5GENIDN
Idaho
Just have to clean them up for a remark. Had to do that more than once.
PWillette
Parrie
Maine
I may add...make sure your torque wrench is calibrated. While installing my ICON UCAs I was torquing said bolt and snapped it clean off.
