PSA if you use a pressure washer to clean your Bronco Raptor bumper.
Adam
Houston
Ford F-150 Raptor
While washing the Braptor today I accidentally damaged the rubber piece above the bumper. Just a heads up if you use a pressure washer the rubber is soft enough for the water to tear it up. The pressure washer I have is not even powerful it’s a cheap electric one.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
I've been using my pressure washer for a year on my Wildtrak. Seems more like user error
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
my 'cheap' electric power washer is more than capable of chewing up concrete when used with a very narrow pattern tip.
what tip pattern were you using?
Theherofails
Thomas
Phoenix
I don't even know what that piece is..? Was this added to later models or just Raptors..?
Either way, use a wider tip! (thats what she said).
dan79
dan
ma
08 f250
I use my pressure washer helps get the sand off everything before I touch it maybe don't use a 0 tip lol
dan79
dan
ma
08 f250
its on my 21 BB
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Looks like it’s a 15 degree tip.
I think even when I bought mine it specifically said to use nothing smaller than like 40 degrees. Something like a 15 is not meant for your vehicle.
Jazer
Jessica
2.7 OBX
Yikes. I use a 40 degree tip for cars (even has a picture of a car on it) and have never damaged anything. Just be glad that all you damaged was that and not the paint.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
What's it do? I just have a gap between my steel bumper and the body panel.
I have it on my bb plastic (incapable) bumper.
It sits there between bumper and lower body-color grill surround and takes the wind like a champ
BeachTiger
South Carolina
2019 Ford F150, 2022 Bronco Badlands
You can get a set of tips off of Amazon for a little over $6. I find that 25 degrees is not too strong for a late model car with good condition paint. But always allow some standoff distance between the end of the gun/tip and the surface being sprayed.
Happycampinman
Ford Bronco
Yep, even a small pressure washer can shred shit with the wrong tip and user error. File it away in the do not do memory
