Sent you a PM with info.Definitely interested in a set of these if you can DM me
Did your kit come with pre-load or did you need to adjust accordingly (without instruction)?So last weekend I finally was able to get time to install the radflo extended length coilovers and camburg upper control arms. Also installed some foutz motorsports rear lower shock skids as well. Install was pretty straightforward, with the rear obviously being much easier. So after driving it, I am definitely pleased. So far haven't been able to get offroad yet, but onroad manners are much better. It seems to handle much better onroad. The valving is clearly a little stiffer. I live off a winding country road and the bilsteins felt a little soft and would have a little body roll when cornering. With these shocks it is greatly improved. I have yet to take it offroad to see how it works, but just driving on roads here in California is pretty close. Will probably get it up to the rubicon after memorial day and see how it does in the rocks. But overall would definitely recommend the radflo shocks. I do need to adjust the front up a little more to even it out but needed to give the wife her Bronco for monday. They are basically exactly the same as the fox in fit and finish and performance.
I have 16" 650# springs up front. There was some preload on it already though. Sounds like I need to make a call to Radflo on these.Did your kit come with pre-load or did you need to adjust accordingly (without instruction)?
What part # is your kit for the extended length (sas version)? We have the same Eibach spring part #s as you do up front, and Radflo just told me these are incorrect for Sas.
Yep, just confirmed. Should be an 18" front spring. They are going to send a new pair out to swap them.Did your kit come with pre-load or did you need to adjust accordingly (without instruction)?
Unfortunate same boat. Lots of extra effort and time thats costing the end user in this case.Yep, just confirmed. Should be an 18" front spring. They are going to send a new pair out to swap them.
Yeah, is a bummer for sure but sounds like they will get it taken care of quickly. Could be worse, could be waiting over a year for some foxes.Unfortunate same boat. Lots of extra effort and time thats costing the end user in this case.
Happens all the time in our shop anymore. Installed some Yukon gears in a new Gladiator after the EVO lift and 40's and the ring gear bolts were not hardened and stretched as soon as we tried to torque them. Called Yukon and said they might have gotten a bad batch. Ordered another install kit form the warehouse same deal. Called Yukon back and let them know that was probably the case. Called the dealer and luckily, they were able to round up enough to finish the job, but what a pain in the arse this stuff is anymore. It used to be every once and awhile, but it seems to happen with more frequency lately. Welcome to the new way of modifying new vehicles.
Yeah. Just read a few of the threads on almost anything here and you see wrong size bolts, no bolts, wrong bracket, something being welded backward, etc. being shipped out. It's becoming fairly prevalent. I've already experience great customer service from a couple of companies re-sending me the correct version of what they already sent.
