This question is based on a Lighting thread of mine https://www.bronco6g.com/forum/thre...-use-aux-6-would-swapping-to-leds-help.68418/ where the solution was to use the harness the lights came with, but cut off the harness switch and use the AUX in place of that one. It works, but I really want something that's more OEM+.
One of the ongoing discussions is about the AUX wiring, and how its not really as robust as it could be. Its been a few years since I had to do any tracing, so I'm rusty, but I've been wondering if it would be possible to just rewire the whole OEM setup? Would it be possible to swap wires and bump up the fuse rating, such as swapping AUX 6 to 14ga wiring with a 20-30 amp fuse? Could the stock distribution block and connecting harnesses handle that, or would it screw everything up?
And yes, I know the real solution is to get more modern lights for lower amps, but I love the 500s. My only thought was an H3 LED, but apparently those are all useless, and the Hella H3 upgrade is a fog bulb and these are driving lights.
EDIT: see solution below
