ROLL BAR DELETE
Bruno
Bruno
Montclair
I am interested in more clearance in the back area, for standing with a pop top camper with access from the inside.
1) Anybody know if the Bronco would fold up in on itself if you deleted the roll bar?
2) For example what if only : the roll bar rear cross bar was deleted?
3) What if the rear cross bar was deleted - and replaced with the mid-cross bar as found in the Raptor?
Any insights would be appreciated!
AMTRV
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
No way would I risk the structural stability by removing the rollbar.
Layman
Voorheesville
2022 Bronco Badlands 7MT
I am with AMTRV. This is a bad idea. My guess is you will not get any feedback on this, because no one has tried it, because "this is a bad idea."
Rspayde
North Ga
2019 XLT Ranger
I would be interested in a pop-top camper top that was full integrated into the Bronco top. Some day we will get it just not anytime soon. Until then I would not advise messing with the hard top design to much. Hardly works as is.
BlueBronco
DFW
'16 F150 KR - '21 Bronco BL x2
Only one way to find out...
I in no way recommend doing what you suggested but the only plausible way would be option 3, but instead of using the BRaptor bar, maybe relocating the existing bar 18" forward or so. I am very pro DIY but, again, I don't recommend doing this. Just, no, don't do this.
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
It's body on frame construction. It won't fold up. That said you will likely have issues with the body itself. Doors and rear door would likely stay aligned. You would need to add in some bracing to keep things where they belong.
Dusty
Mentone, CA
70, 71 & '21 Broncos
Most of the dissenting opinions you'll get are from people who have never built anything. But of course this can be done by a COMPETENT fabricator with the right tools and skills. In fact I think it would be an interesting project. Do like you suggested in option 3. Cut out the rear cross bar, weld in a custom-fabricated cross bar further forward to allow access for your camper. That said, I wouldn't consider this as a driveway mod or DIY project for a first-time fabricator.
There is a legacy for Bronco-mounted campers reaching back to the Early Bronco. I think it would be cool to see that brought forward.
Just my opinion, which is worth what you paid for it.
indio22
Chicagoland, USA
1972 Land Rover, 1985 CJ-7, 1998 TJ, 2014 BRZ
Vehicle Showcase
As mentioned, because Bronco construction is body on ladder frame, you don't have to worry much about body shell integrity (compared to if you were dealing with a unibody construction).
I bet you could modify the Bronco roll bar structure without much issue, providing you take into account that the window surround seals and some other stuff, needs to be kept in same location to function properly. Because that stuff is located by the roll bar structure.
I happen to have a Jeep TJ with back portion of roll bar removed (see photo below). No issues at all. But the roll bar was not doing much else functionally (other than providing a mounting point for rear seatbelts).
Personally, I'd be hesitant to hack too much into a brand new expensive vehicle. That's the beauty of older 4x4s, they can be a canvas where you can do all sort of creative mods. If you do end up modding the Bronco roll bar, please share it would be interesting.
Bruno
Bruno
Bruno
Montclair
Thanks - yea basically just wanted to move the cross bar forward, to be able to stand up back there with a pop top camper.
This company is supposedly making one for the Bronco
https://ursaminorvehicles.com/j30-pop-up-camper-jl-2.html
They have not in the past - but I pray they make the bed fold up, so you can use the back to stand up like this:
** The AluCab Hercules does this:
https://www.alu-cab.com/product/hercules-roof-conversion/
Im super doubtful AluCab will make a Bronco Pop-Up - which sux
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Ask your insurance company.
indio22
Chicagoland, USA
Vehicle Showcase
I've got an old Series Land Rover, and that reminds me, there was a camper option called the Dormobile. There were a few different variants, but similar to those photos you posted, the new popup top section replaced the upper portion of the hardtop.
