- joe
- Oct 21, 2021
- 1
- 59
- 35
- St. Louis, MO
- Hyundai Sonata
- Outer Banks
where did you get the hitch cover?
Ruxer @flip had them in stock as of this morning.where did you get the hitch cover?
Not true. Towing a 3500lb trailer through the mountains, on mountain shelf roads and up/down steep rocky trails, trust me a brake controller is a must.Yes, and I would argue that most towing less than 3500lbs won't need a 7 pin.
Won't argue there, and that's why I said "most." As such, my statement is not false.Not true. Towing a 3500lb trailer through the mountains, on mountain shelf roads and up/down steep rocky trails, trust me a brake controller is a must.
Added to the original post.Nice can you post the link for number 3.....
3. Wiring Connector: Road Tough - $16.89 (Amazon)
Link in your post does not work for this item. This is it correct?Added to the original post.
Yes, that's right. Thx for the heads up on the original post. I fixed the Original post.Link in your post does not work for this item. This is it correct?
https://www.amazon.com/Road-Tough-WeatherLock-Heavy-Duty-Electrical/dp/B07Z6RZCVF/ref=sr_1_3?crid=34DACUWWR9KJW&keywords=road+tough+trailer+connector&qid=1643995979&sprefix=road+tough+trailer+connector,aps,114&sr=8-3
Curt makes a Bluetooth controller that you don’t have to drill the interior panels to fit. And only have to run a power wire toNice work, I plan to do the same.
That said I would’ve agreed with your comment regarding a 7 pin and 3,500 until I did some research and found out a lot more small, light travel trailers and tear drop trailers than I expected do have electronic brakes. It really surprised me that every little teardrop trailer I looked at had electronic brakes even though the ones I looked at weigh less than 2,000 pounds. Anyone considering deleting factory tow should make sure they understand their needs.
THANK YOU!! I will have these parts ready to go when the Bronco gets here!Hello, I thought I'd share my tow package build. I have not looked for a similar post so apologies if it's a repeat. But here is my self made Tow package. I removed the factory tow package to hopefully get built quicker, and it worked. Here is my parts list, and a quick install review:
Parts:
1. Curt wiring kit p/n: 56468 - $79.82 (etrailer.com)
2. Curt Receiver Hitch: 13493 - $104.31 (toysfortrucks.com)
Total: $201.02
Savings over Stock: -$393.98
Hitch install, easiest I've ever done. Seriously. It took less than 15 minutes.
Wiring, was relatively easy other than the Wire running to the battery. Had to get creative on that one.
Total install time: 2(ish) hours.
Conclusion: I got my Bronco early, and saved $400. Totally worth it.
You ain’t lying!Mo beer money! Good call
That’s the 4pin option. It doesn’t work with trailer breaks. You need the 7 pin which at this point is only available from the factory, or you need to go aftermarket.Saw this on the accessories site for the first time:
https://accessories.ford.com/products/bronco-2021-trailer-brake-controller-towing-pack-1
I know NOTHING about towing, so don't crucify me if it doesn't solve the braking issue...
