Squeak coming from Cargo Area - Fixed ✅
Nomadik
East
2021 Bronco FE
Can this happen on the 2023 ? Bronco Wildtrak . I have the same issue
The
The tailgate squeak can happen to any of us with the bronco or jeep...the fix with the krytox/weatherstripping was taken from a jeep squeak fix, I believe. The metal and the weatherstripping get dry due to environment and start to squeak where they rub.
If you mean the body squeak with the rubbing panel, this is not as common and across the board. I haven't had this issue 🤞. I don't think most have had this issue but It looks like a few people have had an alignment issue from the panel/strike plate/etc...but still doesn't seem as common as people who have had no issues.
kiddinaround00
Toronto
2021 Ford Bronco Outer Banks 2dr
Adding to the thread. I fixed my squeak using permatex synthetic grease (I can’t buy Krytox in Canada) and applying a thin layer to the outside rubber portion of the back window. The squeak went away immediately.
Wharthog
Bozeman, Montana
Silverado
One more add, I had a squeak that was not fixed by any type of lube. I tried the panel fox and that helped a bit but the squeak persisted. I noticed that the passenger side of the top with no squeak was resting higher above the rear quarter panel than the drivers side with the squeak. I took one of those round felt pads that you put on the bottom of a chair leg and placed it on top of the drivers side quarter panel to lift up that side of the top. No more squeaking!
mbdlds
Has TSB 22-2097 been updated for the 2023 model year? I just started getting a loud chirping sound when go over bumps after 8 months of no issues.
Trialmx
Jack
Ohio
2022 Bronco
Never had hard top issues like many others, no squeaks or noises from anywhere except plastic rattle around the sub with certain music. After a year or so I noticed a faint squeaking/metal/plastic bottle sound coming from the rear. Found the hard top cap passenger side fitment TSB, and yes mine is tight. The fender and filler panels have always looked wonky. However, while playing around I noticed a really annoying loose fit that seems to be my squeaky culprit. It is the fitment around the passenger tail light and rear fender. Driver side is nice and snug and doesn’t squeak at all, but the passenger side is crazy noisey. See video.
My pax tail light has a bit of a wiggle to it. I didn't suspect it was squeaking but after seeing your video I'll look into it more. Thanks for your post.
Packen8
Jerry
Maine
Ram 1500
That’s something that just should not happen with any new vehicle any brand…. Terrible ! Fingers crossed no issues yet other then my driver side door was loose upon delivery it will be a year in January …..reservation on 7/14/20
DFR
Don
Central Florida
2023 Ford Super Duty, 2 Ford powered rock crawlers
I applied the Krytox this morning...we'll see how it works...
DFR
UPDATE...UPDATE...UPDATE - 12/07/2023
The Krytox works as advertised and that annoying squeak when on a wash board/bumpy road is gone...
UPDATE...UPDATE...UPDATE - 12/19/2023
After several wash and wipe down cycles the Krytox continues to quiet the squeaky rear door/window assembly.
Meloco
Bronco edge excape
Has anyone tried this stuff instead of Krytox.
Ford Bronco Squeak coming from Cargo Area - Fixed ✅ 1000000105
telenerd
Laramie
Subaru
I got the water bottle squeak. Removed spare and found some loose bolts for the carrier. Squeak still there. Today I rode in the back of bronco to verify it was a seal and it was! I was worried it was the tailgate or top.
Cleaned the seal and was quite dirty. Then used Vasoline to soften up the seal. Why spend money on that Ford special lube when I got Vasoline handy. 😂
Will report back!
telenerd
Laramie
Subaru
Well cleaning the rubber seal on rear hatch and applying Vasoline to soften it up fixed the issue! No need to order that tiny Ford lube bottle! 🍆
Dialtone
Twilight Zone
Bronco Big Bend Mid
If that uses petroleum as a base I'd avoid using it on door seals. From what I read I saw no recommendation to use it on soft seals of any kind..
Ksjrb03
Ksjrb03
Tx
F250
I would not use vasoline or any petroleum based product on these rubber seals, will degrade them over time. The krytox is used for a reason. You can also add some felt tape or other stripping to stop the seal on paint squeaking.
telenerd
Laramie
Subaru
Hum okay. I will wipe it off and try a silicon based lube. Thanks for tips.
