tailgate reinforcement weight limits?
brkdncr
Southern California
Toyota 86
Does anyone have a guess on what the weight limits are for the two types of tailgate reinforcement? I see one type re-uses the standard hinges, while the other types replace those hinges.
PWillette
Parrie
Maine
The standard OEM tailgate/hinges are rated for 133lbs. The brace type reinforcements that utilize the OEM hinges will make the tailgate more rigid however they do not increase the weight capacity. Others utilize a Raptor style hinge which does increase the capacity but I forget the number. Maybe try a search.
35tires
'23 Bronco, '21 4Runner
Turn offroad has one that replaces the hinges entirely. I think 2 or 3 others do as well. @Turn Offroad what's the weight limit of that tire carrier?
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Considering they lifted their Bronco by the spare tire with a forkliftā€¦ Iā€™d say A LOT
brkdncr
brkdncr
Southern California
Toyota 86
yeah search didnā€™t turn up any tested weight specs.
i was under the assumption that the current weight limit was because the tailgate would flex, but was not the limit of the hinges.
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
Iā€™m really intrigued by the TOR tailgate reinforcement. I think Iā€™ll buy one of those when my squatch needs new (heavier) wheels. I donā€™t know the weight others are rated for but from my research TOR looks to be the best.
604Bronco
British Columbia
www.bronco6g.com
At 5:40 into their video they lift the Bronco by this tire carrierā€¦ I think itā€™ll hold a lot of weight.
I have one and itā€™s awesome and great quality!
PWillette
Parrie
Maine
35tires
I have one still wrapped in the garage I haven't gotten around to installing. I almost tossed it up for sale just to clean the garage out.
Hmm, I couldn't find the Raptor tailgate weight limit anywhere. Makes me wonder if the Raptor hinges really are rated to carry any additional weight, or if they just have the accessory points and cross bracing built in.
Durangatan
Marty
Durango, CO
Bronco, A6 Avant, TTRS, SQ5
Not necessarily. Having sat on a few ASTM committees to determine testing protocols for outdoor equipment the forklift test tells you nothing. I'd like to see if ASTM has a standard for testing this. It would likley include a dynamic testing component, and would likely measure downward dynamic force. Or what we in the industry refer to as a dynamic G-Force test.
Broncobro04
Alex
Jacksonville, Fl
2021 2 door Bronco
I guess the question is what happens if you exceed the rating on the hinges? Everyone says the stock hinges are rated only for 133 lbs but I have like 230-250lbs of weight on my hinges and itā€™s holding strong with a Hammer Built tailgate reinforcementā€¦ no sag, no crunches, no flex
dadjoke
Southern California
'22 Bronco Big Bend 4-Door 2.7 MIC Auto Sasquatch
I've asked vendors directly before and the answer given to me then is that nobody's willing to test to destruction or assign a limit based on assumptions. It's a bit of a bummer, but I understand
It is pretty hard to test dynamic stress loading and CYA
