The questions that don’t deserve their own questions thread (2021 Ford Bronco)
Stuckin918
Oklahoma
2019 Colorado ZR2 Duramax
Do we know the speed the crawler gear moves at with 4L engaged at an idle? Yes iys like 94:1 drive ratio, but whats the rate of travel?
Having flashbacks to math class now.
If Jim is traveling in his Bronco in 4 lo and Mary is traveling the opposite way in her Wrangler in 4 hi. How long will it take for Mary to roll her Jeep over?
BMG40
New York
2018 Jeep Grand Cherokee High Altitude
I’m still curious if anyone figured out why the Badlands 2.7 can’t have the sound deadening headliner? I know most claimed it was a B&P error, but it still hasn’t been corrected.
j_marinelli
Spring Branch, TX.
Wait I'm confused now. There is a ton of threads with questions that don't need to have their own thread already. Dang it @Fordboi , you are turning this forum into the Matrix. race red pill or antimatter blue pill?
Laminar
Iowa
Cougar
Assuming manual trans, 4A transfer case, 34.5" tires, and 750rpm idle speed, you'll be moving at 0.81 mph.
Austin26
Austin
Houston, Texas
2019 Subaru Crosstrek
I've been wanting a measurement from side to side on the interior at the narrowest point, likely between the fender wells, and the distance from the inside edge of the back cargo area to the dash / media screen with the seats folded down.
OK_Hunter
Greg
Infinity g37
0.81 mph was very close to my calculation as well with 32" tires and 800 rpms (0.94 ratio)...??
Laminar
Iowa
Cougar
You can't get 32" tires with the 4.7 gears from the factory.
If you're talking Black Diamond, that'd be 31.7" tires and 4.46 gears. With the 4A transfer case it ends up being a 90:1 crawl ratio, and with the smaller tires it actually ends up being 0.79mph @ 750rpm.
Reaper
Dodge Ram 1500
Let's hope. I also realize that there were potentially millions of combinations that could intertwine and there was no way to figure it out until it was rolled out. Lack of ability to do beta testing probably contributed to it...
We are the beta testers ?
brunjc2
Jud
2002 VW GTI
Assuming the Goodyear Trritory tires will be the same height as the Duratracs (34.4”), and engine idle of 800 RPM,a Sasquatch Manual will crawl at just under 1 mph, as I calculate.
https://4lo.com/calc/gearratio.php
Ford Bronco The questions that don’t deserve their own questions thread (2021 Ford Bronco) F8AF594B-1065-451A-9F45-4E2E944579DF
flatlander40
1. Do you have to have rock crawl GOAT mode to do one pedal drive?
2. Has it been confirmed somewhere that Sasquatch package upgrades all models to the 210 axles?
Used2jeep
Massachuvian
2007 Crown Vic P71
What happened to all of the "<Suchandsuchtrim level> just rolling off of the line at MAP" pictures? I would expect that they are still being made. Most likely in varying trims as well as Squatched/not Squatched. It would be nice to see those.
Used2jeep
Massachuvian
2007 Crown Vic P71
1 - 2.7 and advanced 4wd.
2 - Yes, I believe the original PDF.
SamR
Tucson
4Runner
i keep on getting tons of little questions in my head that don't deserve their own thread and there isn't and available thread where the question would be on topic. I'll start us off.
What is the lowest trim available with Area 51?
i won't know all the answers, but others will.... i sure hope dealers won't have to ask questions in here. shame on ford if that happens.
https://www.bronco6g.com/forum/thre...s-wallpapers-photos-videos-colors-trims.1776/
About halfway down you'll fine the colors/trims list if anyone has more questions.
#2 is sorta answered in the link above but to directly answer it, it has been confirmed.
SamR
Tucson
4Runner
Do we actually know the difference between SAS suspension and the standard suspension besides the fancy shocks?
edgeflyer
2013 FX4
Logically speaking, the gun will not fire unless you make the wrong choice. Therefore, it will not fire either if you make no choice. So my advise is to forget Mike Levine and make no choice until after the gunman leaves.
I'm pretty sure creepy uncle Mike is anti gun. Just saying.
