This may sound like a feature... but my auto stop/start seems to never operate anymore...
Ares
Fox
Atlanta
I didnt really notice when it stopped working... but now everytime I stop I just get the little gray with a slash icon on the dash indicating that auto stop start is not available.
I initially thought it might be because it was hot, but today I was driving with the AC off and it was 70 degrees out, and still wasnt active.
Now that I think about it... the doors were off, is it possible that auto stop start doesnt function with the doors off? I took them off about 2 months ago and havent looked back.
DoubleADuster
Aaron
Maryland
1963 Ford Thunderbird
You’re not in sport mode all the time are you?
Ares
Ares
Fox
Atlanta
nope, just normal mode, I even tested eco mode, still nothing.
nothing plugged into any outlets or 12v plugs. no forscan
DoubleADuster
Aaron
Maryland
That’s the extent of my troubleshooting knowledge. Good luck, or maybe not good luck and you just saved yourself having to buy the auto start/stop disable
‘21OBX
90Bronco19
2022 bronco outer banks
The grey icon means there is a fault not letting the auto stop/start work. An abs code set can cause this error.
Ducati1098
2022 Bronco Wildtrak, 2012 Ford Fusion
Not necessarily. The grey icon just means it hasn’t met all conditions to activate auto start stop. Could be a lot of reasons, even when no fault is detected.
Ducati1098
Auto start stop will not work when there is a door open.
Ford Bronco This may sound like a feature... but my auto stop/start seems to never operate anymore... 2B7F39A5-01FC-47B3-931F-E438275C85B2
Ducati1098
I think this is the answer, no doors = no stop start. Wierd, but it explains it
I just edited my post with a picture from the owners manual showing certain things that can prevent it.
‘21OBX
90Bronco19
My choice of words were not great. conditions not met certainly sums it up better than fault. 👍
Ares
Ares
Fox
Atlanta
welp, I put the doors on today. still no start stop.
another reason I need to visit a dealer I guess
gwp
Greg
Winchester, Virginia
Harley Davidson FLTRUSE
Did you get this resolved? Same issue here. Stopped working. Thought it was because I had removed doors. Vitiated dealer. No codes, no ideas. Doors back on. Still greyed out / inoperable.
Ares
Ares
Fox
Atlanta
nope, no solution. it kept not working when I reinstalled the doors.
but then started working again, even with doors off.
this issue and the intermittent parking brake failure on startup might be related for me? but I have no faith that a dealer can fix either since it happens intermittment. Hard to demonstrate it, or for them to know its been fixed. and I dont want the dealer to just go fishing around in my dash seeing how many rattles they can create in the process.
  • Like
Reactions: gwp
AZ_BRONC
Tempe, AZ
‘17 4Runner, ‘16 BMW 328i, ‘96 Stang GT, ‘19 Mini
Mine stopped worked when I took my doors off, but starting working again a few drives after I put them back on for the hot Phoenix summers. Once it got really hot it stopped working again, unless it’s cool in the morning. There are a few threads about this issue as well as a “hill assist error” that triggers on FordPass when the doors are off.
