'Ultimate Stereo Upgrade' Thread
DaveInSA
Seguin, Texas
2021 Bronco Badlands 4DR, 2007 Saturn Sky
🤔 Hmm…i also dismissed this idea based on the same reasons! I would like to see a photo of this particular component of the build! If it’s feasible then that’s the route i’d rather take!
I was just looking at the hideaway 8" and measuring under my seat with stats from crutchfield...
14 1/4" long, 9 3/8" deep, and 3 1/4" high. The length is larger than the space between the seat rails by just a bit. The depth would have it sticking out in to the foot area of the passengers a couple inches (on a 2 door).. and the height might be tight. I don't have the rear ac vents on my non-sas badlands w/mid package, but there is another hump down there taking up space.
I too would like to see pictures of one installed under the seat.
Guess I could put it in the cargo area too, but I really don't want to reduce cargo space.
roofone2
Boston
A4
Absolutely. Butter smooth. Very much worth the steep price!
How'd you get the GS42s to fit in the dash?
They seem too tight...and not sure the holes will match up with the ones there.
(Thanks!)
fitterhappier
Adam
Round Rock TX
2022 Ford Bronco
(Thanks!)
That’s a good question. By default, the GS42 holes do not line up with the factory ones. I ended up using a washer to lock one of the sides down (using the screw to go through the factory hole and the washer makes contact with the GS42 hole), and then installed the other side through the factory hole. Been holding solid for a few weeks now. I bet there’s a more elegant backstrap solution, but surprisingly Crutchfield didn’t automatically recommend anything like that when I purchased them. No issues whatsoever with depth.
roofone2
Boston
A4
Thanks for the write up.
I ended up clipping off one part of a hole on each side (so they end up looking a bit like a C). That provided enough material on each side for the screws to hold it securely.
They sound awesome — clearer than the JL C1-400s I had in there, but does seem like they’ll benefit from some break-in.
I’m trying pairing them with Memphis MJP6 mids for the kick speakers.
F OR D
BD Green Machine
people that did it put washers/spacers to raise the seat up. the hideaway is small enough to put in the back imo. gonna try next weekend; i've seen a few people just mount it to the side of the trunk with two screws, or just leave it laying down.
BigMeatsBronco
Allan
2021 FE 2 door
How’d you get the hideaways under the front seats? I had dismissed that idea based on many others indicating it wasn’t feasible.
I used spacers and threaded rod ....I raised the seats just over 1"...heres pics. This is a 2 Dr mod...more dores need the heater duck removed or rerouted....a much bigger job on the moredoor.
BigMeatsBronco
Allan
2021 FE 2 door
Easy on a 2 dr
BigMeatsBronco
Allan
2021 FE 2 door
Sounds like a good system.
Since you amplified the kick speakers, did you have to add anything like the Zen interface to mitigate the B&O DSP?
No, I just used the kick speaker as inputs to the new soundstream amp ... I tried the amps built- in hi and lo pass crossovers, but like the way it sound better in full range position. I assume this is because the B&O system is already sending a (relatively) low pass signal to these.
They speakers are made for 300hz and lower but definitely respond to higher tones than that
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Question regarding speaker upgrades from the factory B&O system...
I read that the speakers that come with the B&O from factory are weather-treated to withstand the elements of off roading/topless driving.
So my question is, when upgrading, should I take into consideration the weather ratings for speakers and associated components? Back in my hey days, most speaker cones were made with paper like fibers and I doubt any of those were waterproof.
MTmeterguy
Jeremy
Sidney, MT
2007 Ford F-150
Finally have all drivers ready, now I just need to decide on amplifier......oh and get my Bronco 🤣
Will be going with Stereo Integrity BM MK III sub, Hertz 6.5 mid bass and Stereo Integrity M3 carbon up top.
BRBlue
Houston
Toyota Tundra
I wouldn’t sweat it. All of the B&O speakers have paper cones. They may be “treated” with wax or something. You could always get boat speakers but if you’re going to expose the interior to that many elements you will have bigger problems elsewhere.
Kyukidoeric
Panama City Beach Florida
2022 Bronco (former 69 & 77 Bronco owner)
I see a couple of y’all spent some $$ on your systems. Sheesh! LOL. I love em all! I took a cheaper route and went with a Skar bundle. Spent around $500-600 for everything.
Ford Bronco 'Ultimate Stereo Upgrade' Thread PXL_20220530_030110823
I just replaced all 6 of my speakers with Skar. I'm impressed so far, just under $98. And one day I plan to add my sub and amp, just have to get around to it. But for now, I'm happy with the change.
2fast4u
Rancho Cucamonga CA.
Shelby GT500 and Bronco Wildtrak
Do you have one under each seat?
