Nodrama43
j
under the big tent
nunya
My top is getting painted black……problem solved.
BAUS67
redneck
Central PA
zzcoop
A-A-Ron
Kansas
www.postrockimages.com
2021 Bronco Black Diamond
navi
Navi
CA
73 Bronco
I can see the same pattern showing through on mine, although not as bad. But it also has not been in the sun much.
On the other hand, I have another small section that is obviously delaminated from the top core. Meaning the outer layer is separated from the honeycomb. When I tap it it has an obvious hollow sound, unlike the rest of the top. Similar to tapping on floor tiles, the ones that do not have best thinset bond have a different sound.
Well, obviously you didn't wax it. If you want the full effect of the new honeycomb look you gotta wax and buff the shit out of it.
Ford Bronco [Updated 7/20] Early Delivered Bronco MIC Top Developing Honeycomb / Snakeskin Pattern tenor (3)
Oceannomad
Jonathan
SE Virginia
2021 Audi Q7
Also happens when you give engineering problems to project managers.
To be fair, as a project manager (govt) I always refer to my SME engineers with the knowledge. But I can tell you, shitty acquisitions happen in all sectors.
Quinn_the_eskimo
Cave Creek, AZ
1981 Jeep Scrambler, 2021 Jeep Gladiator
Point is, all these fellow forum members saying a coating caused this is absolutely unbelieveable .... and if it is the case, Ford definitely needs to be made aware because the fragile POS won't make it through a single Arizona summer or a midwest freeze thaw cycle ...coating or not.
On the jeep forums they'd be looking at the post history and calling them a troll. Thankfully we haven't gotten that far here... Yet.
DFNMAN
Anthony
Tampa, FL
21' 2dr, 15' M3, 07' FJ, 03' M3, 79' 928
The seam on the top section of the roof is uncoated too.
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S
Your tapping is actually part of the pre-flight on a composite airplane. Hollow sound=no flying.
ReimundKrohn
Reimund
Three Hills Alberta
2016 Rav-4, 2005 F-150 Lariat, 2005 PT GT Conv
Textured plastic isn’t made to be waxed. It is porous, and you have wax trapped in the pores highlighting the honeycomb structure under the surface. You haven’t damaged the roof, but you marred the appearance of the roof by waxing it. You will need to consult someone on what product you can safely use to draw that wax out.
https://www.carwashcountry.com/how-to-get-car-wax-off-rubber-or-black-plastic-trim/
TNcoupe
Decatur,TN
2022 Badlands, 1970 Bronco, 1955 T Bird
Nope, still hate the idea. I'll take a honeycombed split edged removable top over a flawless fixed roof every single time.
I'm just the opposite. I'd take the non removable roof all day. Doors off a bunch, top will never be off for me.
DEC
Derek
SoCal
BMW 640, Mustang Bullitt, Mazda 3, Honda Accord,
The product he used says it’s ok on rubber and plastic trim.
Carbon Bronco
Washington
1969 U15 Bronco New Lime 302ci
Took me a while to remember where I had seen this before. 80s tv show called V. You got the V edition.
Ford Bronco [Updated 7/20] Early Delivered Bronco MIC Top Developing Honeycomb / Snakeskin Pattern unnamed
