- First Name
- Brandon
- Joined
- Oct 5, 2020
- Threads
- 49
- Messages
- 605
- Reaction score
- 1,493
- Location
- Utah
- Website
- www.puravidaoffroad.com
- Vehicle(s)
- a number of classics and my 4dr Badlands
- Your Bronco Model
- Badlands
- Thread starter
- #1
Even after reading page after page of how to wire fog lights to the Badlands mod bumper with Lux, I still had questions, so I thought I'd post pics for anyone else trying this. This assumes you have the factory wiring harness/plug buried in your bumper.
Remove the plastic covers over the recover points and you can easily access the factory harness connector. It's held in place by a plastic clip which is kind of a bitch to release, but keep at it from the backside and you can get it to release. I cut off the factory connector and used waterproof soldered butt connectors to splice in a new black and red wire that would reach the new Diode Dynamics fog lights. The yellow with orange stripe is the + for the passenger side and the brown is + for the driver side.
I didn't have the proper Deutsch style wiring connectors to plug my new red and black wires into the existing Deutsch connector, so I just cut the (+ and -) wires coming out of the connector, leaving a pigtail, and used another pair of waterproof soldered butt connectors to tie the wiring together. This also allowed me to leave the existing purple wire untouched, which powers the backlights and merges with all of the other purple wires and leads to a fuse tap I added to the fuse box.
Tonight I'll be in Forscan enabling the settings for the new factory Fog light switch I replaced to actually make them work.
Edit to add the switch I ordered - M2DZ-11654-DA. Took about 10 days for delivery through my local dealership. I don't have an interest in rear fogs, so this one is perfect.
Forscan Update:
I pulled the Forscan settings from this post in the massive fog lights thread. To summarize:
BdyCM Configuration
Here's the headlights only vs. "Everything on". By the way, I didn't think I'd love the amber backlighting as much as I do. They look awesome.
@Diode Dynamics everything, sourced from Panda Motorworks :
Forscan Update:
BdyCM Configuration
- Front fog lamps - change this to "Enabled".
- Fog Lamp Switch - change this to "Enabled"
- Using Front Fog With High Beam - "Allowed"
- 726-42-01-xxxx-xxxx-xxxx - Change the green value to 0101
- SS3 Sport Amber fogs
- SS2 Pro white combo
- SS2 Sport white driving
