I think your spot on with the BD 2.3! Plus don't get a ridiculous lift, stay at 2" or less and don't go over 33" tires and you should be good!
My base Sas 2dr 2.7 has 23,264 miles on it. Dec 8 will be one year. The dealership techs have yet to get their hands on it. It flashed the hill holder fault 5 times. Just an electrical gremlin, it hasn't ever actually stopped working. This thing goes ALL OVER. One of my kids sells Fords. You always want to go with the bigger engine because they don't have to work as hard. I had a 2.3 Ranger. There's no comparison in my mind. The 2.7 puts out more torque than the 5.0 coyote engine... wikiI’ve been trying to keep up with the problem spots on the Bronco, preparing to finally buy my own. The two biggest issues I’ve seen have been the 4x4 cutting out (overheating error) when in sand/wheel spin that appears to be on models with the advanced 4x4, and the 2.7 seems to have a lot of problems.
With that being said. What other major/common problems does the bronco have to be aware of, and how can they be solved by either factory or aftermarket solutions?
At this point I’m thinking a Black Diamond, non sas, 2.3, mid package.
older cars have better longevity though. I have two vehicles that are over 50 years old. They don’t have a lot of unique electronics. The drivetrain components aren’t complex.The older cars can’t come close to the reliability of modern cars.
Any forum magnifies any issue dramatically.
I know plenty of Ford owners with F150’s that have over 200,000 miles
with just normal maintenance.
I was a young man in the 70’s and 80’s and remember how unreliable cars were. Having to do tune ups including adjusting points, timing and spark plugs as often as 3000 miles.
Adjusting valves was really fun.
Most folks don’t even know what points were.
Most people that break their Bronco don’t drive properly.
If you put large tires and drive like you stole it you’re going to break it.
Or less you buy a Toyota 4 Runner then it’s bulletproof. But the Bronco can try . Trust in fordNo build is bulletproof.
Especially not the Cybertruck.
Any vehicle can have issues or a part that fails. Just need to maintain it the best you can and drive properly.
This is the first I have heard that the four door bronco has more problems than the two door. Can you be specific as to the problems youBecome one with the non-SAS 2.3 gang. And get it in 2 doors, too: more doors is more problems, after all.
I think he's talking in jest.This is the first I have heard that the four door bronco has more problems than the two door. Can you be specific as to the problems you
As was I.I think he's talking in jest.
I can guarantee with 100% certainty that there will be no 6G Broncos that are alive 50 years from now, except for very rare units owned by individuals with lots of money. And the reason is, as you stated, all the electronics. There will simply be no spares for electronics past a 15 year or so lifetime, and unlike mechanical parts, you cannot replicate them unless you have a $1B semiconductor plant, the original design files, and the original fabrication process.older cars have better longevity though. I have two vehicles that are over 50 years old. They don’t have a lot of unique electronics. The drivetrain components aren’t complex.
I probably won’t be around to see a 50 year old bronco, and they will be less likely to exist.
we may see some stripped out builds though. Rip everything out, replace the drivetrain, replace the displays with tablets.
