Due51
Bronco, Silverado
Happy
Jerry
Missouri
CJ5, Wagoneer
I still wonder about this. If it is important and Ford built it as a feature, why did we/I have to learn about it on an Internet forum.
Did I miss it when I read the manual? Do my other 2 Eco-boost engines need this and their owners manual not mention it?
da_jokker
Jeep Wrangler JKUR
what do you mean they redesigned the heads? where did you hear that?
There are boatload of threads about the 2.7 engine And I follow many of them so I don't recall exactly which.
But I believe all the information about the part number changes in the engine updates are part of the big 2.7 blown (currently 31) thread.
da_jokker
Jeep Wrangler JKUR
So far the only data I have is:
- Completely cold (right below full hole)
- 15 mins after being at full temp (3/4 to top hole, right near top of hatched area)
- Several hours after being at full temp (right below full hole)
And this is with 6qts
It's kind of odd if I'm reading it correctly because it sounds like you are reading are pretty consistent. Yet we've seen many others whose state that their oil level will go from the max line all the way up into the twist if they let the engine sit long enough.
This has to be one of the biggest unsolved mysteries still outstanding on this forum. (Well besides Ford's decision making process)
buzpro
Binky
Tacoma
its no mystery .... @NotApplicable said he put in 6 qts .... at 7 he would be up the twisty
Due51
Bronco, Silverado
Still a mystery when the engine takes 7 quarts but the dipstick tells me I'm way over filled.
buzpro
Binky
Tacoma
oh yeah, THAT! well, its not a mystery, its Ford at its best, cuz they keep ignoring it!
NotApplicable
BEVs
Hopefully I’ve got enough in there… the dipstick says so! Lol
da_jokker
Jeep Wrangler JKUR
Yeah the mystery is the whole quart versus dipstick reading.
But even with the people that are up in the twisty, I didn't think that they were in the twisty at the 10-15 minute check? And only got there after say an hour or more.
shimmy825
James
Los Angeles
2017 Mazda CX-5
so now that people are getting their broncos...and changing their oil - are we getting a full 7 quarts? what's the consensus? changing oil on my new truck shouldn't give me this much anxiety.
NotApplicable
BEVs
bytheway
bytheway
Brice
Louisville, KY
Getting ready for my 2nd change and there’s still no answer. Last time I started with 6 and added another 1/2 quart even though my dipstick showed full with 6. Added more after @flip said his engineer confirmed 7qt capacity. So basically ignore the dipstick and ignore the manual and shoot the gap in between for me.
buzpro
Binky
Tacoma
Astounding how Ford has STILL not addressed this
da_jokker
Jeep Wrangler JKUR
Well they're too busy with all the blown engines to wory about how much oil they need to put in it.
NotApplicable
BEVs
I ended up adding another .125 qt, so right around 6.125 put me at just below the max fill hole, tho reads a tad lower (near top of hatched area) when checked 15 mins after being driven…
I really want to avoid ignoring the dipstick altogether because then we have literally no way to reason about how full it is >.<
