I don't see how? You can ignore all of the pre run locations and run your own if you choose.Plug and play restricts your options.
It looks pretty simple to hook it all together, but it sucks that they only ran two wires through the firewall. They could've sent six through to the glovebox and two to the top and rear from there with minimal extra cost.It doesn’t get much more plug and play than this when it comes to aux wiring. Both the f series truck and new Jeep aux wiring is just wires that terminate in the engine bay, and you have to run everything else. With this, for a roof mounted light bar (probably the most common use) or accessory in the rear it’s done. Just connect it up, ground it with a self tapper to bare metal and you’re in business.
They could have ran as many as they did for the Raptor.It looks pretty simple to hook it all together, but it sucks that they only ran two wires through the firewall. They could've sent six through to the glovebox and two to the top and rear from there with minimal extra cost.
Actually there are 5 pre-run wires, 3 are powered already and 2 are not, grill, top of windshield frame, 2 behind the glove box, and one in the right rear 1/4 panel, that leaves one open relay for a custom run. Not saying you can't put more than one accessory on a switch, being mindful of amp load of the relay. At least this how I read the info.
You gotta check out the rest of the thread. There are 3 prerun wires for theswitches and 3 open forcustom wiring
lol what? how much simpler do you want it? each switch is color coded as are the pre run wiring points the BN guy had shown. You are literally just connecting two sets of wires...So damn convoluded, i mean everything else on these Broncos are plug and play, modular and all etc why not this as well
Sorry - probably a rookie question here. I am looking to add on-board air via an ARB compressor (single). The specs on the device say the load/no-load amperage is 25.2/14.2. Does that mean that in order to use the aux switches to turn this on/off, I would need to use Aux#1 at 25A since that is the largest draw I need to accommodate? Or, is there some other type of fuse in the wiring harness provided by ARB that would handle this? Would it be better to use the provided switch to the compressor and just trigger it from the engine bay? Thanks in advance!
3 relays are open for a custom run. Like I said read the thread.Actually there are 5 pre-run wires, 3 are powered already and 2 are not, grill, top of windshield frame, 2 behind the glove box, and one in the right rear 1/4 panel, that leaves one open relay for a custom run. Not saying you can't put more than one accessory on a switch, being mindful of amp load of the relay. At least this how I read the info.
wires E and D terminate at the glove box so you can’t wire directly to them. They would have to be connected to wires B1 and B2 to have power. C goes to the grille. At that point you have B1, B2 and C using a switch. Then you have 3 open switches.
Yes, I agree. I might not add items right away that tie into the Aux. switches, but it sure is nice to have that built in with all the wiring.Best spent $195
ARB *most likely* includes a wiring harness with a relay. You would plug their relay into the winch and instead of their on/off you would use any of the the Aux switches to turn the relay on/off.Sorry - probably a rookie question here. I am looking to add on-board air via an ARB compressor (single). The specs on the device say the load/no-load amperage is 25.2/14.2. Does that mean that in order to use the aux switches to turn this on/off, I would need to use Aux#1 at 25A since that is the largest draw I need to accommodate? Or, is there some other type of fuse in the wiring harness provided by ARB that would handle this? Would it be better to use the provided switch to the compressor and just trigger it from the engine bay? Thanks in advance!
Perfect and simple. Yes.
