$475 Hooke Road Discovery Roof Rack -- Review
DaveH
14 Ford Focus, 98 Ford Expedition
swooshdave
Portland, Oregon
Mustang
Here’s my mini review part 1.
I ordered on the 16th but it took a few days to ship. It' didn't get here until the 22nd. Normally California to Oregon is just a coulple days.
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0437
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0438
They need to improve the packaging. A lot. The box is very, very heavy and the cardboard box barely made it. Definitely some reinforcement on the ends. I'm sure the FedEx folks don't like the heavy box.
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0439
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0440
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0441
Nothing missing and sorting the hardware helped.
The back half went together just fine, no issues. No misthreaded holes.
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0443
So I’ve got the back half on. I ran out of time for the rest so that will be part 2.
Impressions so far are that it’s not bad. Really sturdy. I was surprised that the cross bars are so wide and have the T-slots.
It’s definitely worth the price. I can’t imagine how a more expensive rack could be that much better.
swooshdave
Portland, Oregon
Mustang
Got a Roofnest Condor XL! I love the way it fits on top and it folds out to a King size.
To be able to take the roof panels off with the roof top tent on I got 30mm M8 bolts - no problem after that just as before! Also, here are some pics with the front 3 roof panels off for proof.
So can you go into more detail as to how you mounted the tent? Did you have to remove the roof panels to get the underside of the tent?
What do you mean you got some M8x30 bolts? Which ones did you replace?
As you saw I got the rack on but the tent is next. I think most racks you can get the crossbars off by lifting up but not this rack.
swooshdave
Portland, Oregon
Mustang
Part 2.
Getting the front section assembled was pretty easy although the instructions are vague (with tiny pictures) as to the actual orientation of the caps on the front. You just keep turning pieces until they sort of make sense.
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0447
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0446
Once I got it all up I went and loosened all the bolts up slightly, wiggled the rack into what I thought was the perfect location and then went back and tightened it up.
Then I went for a test drive. The whistling started right at 55mph and just got worse. Again being the Harbor Freight of racks I anticipated this and bought the weatherstripping.
Which just happened to arrive as soon as I got back from the test drive.
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review IMG_0452
I cut it at an angle on the ends so it matches the brackets. It looks, well, ok. Not ideal but if it doesn’t whistle after the next test drive I’ll be happy.
I do want to get a piece of PPF to put under the weatherstripping.
So for under $500 including the weatherstripping this isn’t bad. Perfect? No. But I don’t even know how long I’ll leave the rack on. Maybe a couple months. Maybe forever.
jacobrdoty
jacobrdoty
Jacob
Sacramento, CA
2013 Mustang GT (Bagged and Boosted) x 2022 Bronco
Yeah I'll actually make a walkaround video here soon about the tent/rack and how the bronco is sitting currently.
rblock50
Ryan
Orange County, California
VW, Bronco
swooshdave
Portland, Oregon
Mustang
Test drive with the weatherstripping results? No whistling. I suspect if they change the shape of the front panel it would also eliminate the noise.
jacobrdoty
jacobrdoty
Jacob
Sacramento, CA
What tent are you buying? I need to film a YouTube video and was thinking of filming my "1 Year of Ownership" type of video so I can showcase the tent and how it's mounted for you (also how to remove the roof panels)
swooshdave
Portland, Oregon
Mustang
https://inspiredoverland.com/products/io-lightweight-rooftop-tent/
Their design expect that you can remove the cross bars, mount the cross bars to the tent then put the whole shebang back on the rack.
I suspect that I will need to remove the rear panel of the rack to reach underneath and then one of the front roof panels to get to the front.
I'll find out on Saturday when I pick it up and install it at their facility.
jacobrdoty
jacobrdoty
Jacob
Sacramento, CA
Ford Bronco $475 Hooke Road Discovery Roof Rack -- Review 3rd_Gen_01-sized
Oh ok sweet it uses the same T channel mounting method as most other tents. Yeah it'll be an easy install without the roof panels on. Just remove the front 3 (I did it while at the person's house who I picked up the NIB tent from and just laid them in their lawn lol).
If the M8 hex cap bolts (double check your thread pitch at home depot) are too long you won't be able to reinstall the roof panels. This is what happened to me. I just loaded up my roof panels in the back and drove home (I had a yoga mat in the back to keep them from knocking around). On the way home I went to Home Depot and got new M8 hex cap bolts for the front (20 or 25mm IIRC..I think I bought a few different lengths to try out. You'll need 4 of each)
swooshdave
Portland, Oregon
Mustang
I don't think I need to remove the center panel. There are just two sets of brackets, front and rear. I'll get to the back brackets from the rear. I'm hoping that I can put the front set just behind the front panels so they will go back on. I'll take pics.
I won't have the flexibility to remove the panels and put them inside as the I will be fully loaded for a mega road trip. Hopefully I won't need to get extra creative.
jacobrdoty
jacobrdoty
Jacob
Sacramento, CA
Yeah then you should be fine! Getting the nuts on rear cover back on can be kind of a pain in the butt, but my gf was able to reach in since her hands are smaller.
doyouglas
Douglas
Southern California
Toyota Highlander
Where is this roof rack manufactured? I went to their website and it doesn't state it anywhere.
swooshdave
Portland, Oregon
Mustang
I have to think China. If it was US it would be plastered all over the site.
