TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Sounds like the vehicle needs to be running if operating the compressor then.
Most certainly. Any compressor you connect to your vehicle should only be ran with the vehicle running, or you'll drain your battery really fast.
Jr87mustang
Josh
Northern Cali
Here are some pics of the single compressor installed. I placed mine as far back as I could incase I needed to use a winch relocation kit. I also added a 90 elbow to keep the hose adapter where I wanted it. Your bracket worked great @4x4TruckLEDs.com , great job.
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 70ADD748-4720-4D97-A843-DA974FC63080
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 552FF5FA-6E04-4B4F-932F-63EED5849F36
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 9136C425-83D8-4FA8-BC1E-56CF0F5D978C
Gene Dios
Atlanta
Ford Explorer
I got around to doing just the mounting. When closing the hood, the quick release chuck doesn't even come close to clearing. And that's with the 45 degree angle adjustment. It presses fairly deep into the hood liner. Not what I was expecting at all...
I think I'll be looking into a complete relocation option soon.
Vtfakie
Robert
2021 Bronco 4dr Wildtrak, Lux, Leather, Tow
Interesting, I don"t aee any evidence that mine hits the liner at all. Seems like it could be close though.
Roger123
Roger
VA Beach, VA
Yea, I didn't realize how much juice these draw, she's hungry!
Roger123
Roger
VA Beach, VA
Is the relay for these on the unit or is it part of the wiring harness?
MOON
2011 Jeep Grand Cherokee
Is anyone just using the switch that comes with it and having that under the hood since it's wired directly to the battery? Is there a good place to mount it, or can it mount to the bracket someplace?
To me it seems like waste to use an upfitter switch for it because you have to open your hood anyways to add the air hose so just use a switch there and save an upfitter for something else.
mark2215
MA
2015 F350
My plan, once I get the compressor mounted, which will have to wait until I actually get my Bronco, is to run a remote hookup out the front somewhere so I don't have to open the hood every time I need air. A couple barb fittings and some rubber hose should make this pretty simple. My biggest concern is keeping the quick disconnect clean so it operates properly. I'm still looking for some type of dust cover for it.
Roger123
Roger
VA Beach, VA
This is what I was planning on doing for the reason you mention. There are some Jeep kits out there that the mounting bracket has a spot for the switch.
Maybe this could be Rev 1 to this product?
Roger123
Roger
VA Beach, VA
This looks like a good option.
https://www.rockyour4x4.com/?product=sherman-cap
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
what truck do you have… 2.3L or 2.7L
Which side is your harness on… driver side or passenger side
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
If you use the ARB quick connect (it doesn't have to thread onto the compressor, you can run some hose and thread it onto the hose):
https://www.4x4truckleds.com/arb-air-hose-coupler-dust-cap/
Gene Dios
Atlanta
Ford Explorer
2.7L
Attached a screenshot where it is depressing the liner by about a full inch of depth. This is with hood down enough for the safety latch but still needs to go another inch for full closure.
