ARB compressor mount options
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Ahh, got ya, cause you were quoting a comment about ARB's temporary mount.
Right now i'm designing it off a 2.3L but once our prototype comes in we'll see if if it fits a 2.7L and what modifications we need to make on it. Eventually we'll have it fitting both engines
Nobody
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
Are you looking at the same location as the ARB photo or something else?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Quick update... our prototype will be here Thursday next week so we'll see how much time I have to test fit it. We're leaving for an off-road event Friday morning so it's a bit tight on time. But i'll try and mount it up and snap a few photos
Nobody
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
Thanks for the update. Looking forward to seeing what you come up with.
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
I spotted this at SEMA at the outdoor ford performance displays.
It appears to be an ARB dual compressor mounted in the 2.7 engine bay and fully functional. Looks like the control module is mounted to the side above the washer fill. I didn't get the chance to ask anyone about the truck since they were busy packing up
Ford Bronco ARB compressor mount options cx4_9CmCd1wTAelDcqYn8Kjrd=w1920-h909-no?authuser=0
Ford Bronco ARB compressor mount options x6N1X0i32kAJXGVsbMcPe16wA=w1920-h909-no?authuser=0
Nobody
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
20 lashes for not getting a photo of the mount!
It looks like another install there. The drivetrain control module doesn't appear to be mounted to anything, and it's covering the surge tank cap.
Ford Bronco ARB compressor mount options 3B20A0A1-31FA-4FCC-9DC5-5C31751950AB
Ford Bronco ARB compressor mount options 3A46093E-BD2E-4A40-BDEC-1B680958D329
Theherofails
Thomas
Phoenix
Hows it mounted? Did you get a look? The only metal anywhere near that spot is the side of the fender, and I dont see any bolts.
Ford Bronco ARB compressor mount options 1636475199322
Blaylock1988
Colorado Springs
It's hard to see from my pic without zooming on the high res one but the control module is looks like its bolted to something here. I don't have my bronco yet so I can only speculate.
Ford Bronco ARB compressor mount options 1636475426464
Jr87mustang
Josh
Northern Cali
Agreed, that looks bolted up to me. I find it hard to believe that Ford has multiple vehicles with the ARB in them just sitting there not attached to anything. In the three different vehicles I have seen its all set up in the same position, they must have made some kinda bracket.
Nobody
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
You might be right. I would consider that a very temporary solution.
Ford Bronco ARB compressor mount options 2F8D1535-38A5-4706-B580-221056F5D740
Blaylock1988
Colorado Springs
from your pic it looks like they used this bolt. I think bending up some metal and making a simple mount for the module wont be too hard, hopefully would be part of the same bracket as the ARB one.
Ford Bronco ARB compressor mount options Screenshot 2021-11-09 094523
Nobody
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
I'm holding out for the ARB mount due out this summer. I was pretty turned off by the threat to sue by your vendor.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
This is the "nicest" setup I've seen yet. Grimm Offroad.
mcinfantry
Lee
Louisiana
Badlands 2 door
I’m going to see if I can mount a maxi trac there
