- Banned
- #121
He just said...a little bit more lift; significantly bigger tires; better and wider wheels; wider flares; taller gears (auto). Not bad for $1,500....So what does $1500 buy you?
Get the Base BL if it isn't worth it to you. People are just trying to help.WOW. The BASE Badlands comes with wheels and tires and 4.7 gearing. If you are going to reply to a tread, you should read it. The difference is $2500 not $1500.
Sorry I asked.
I agree with this. I have questions. Are any changes needed to the front and/or rear bumpers? If you do not will the bumpers stick out? Does Ford sell replacement end caps?I'm replacing my goofy squatched flares with the regular ones. A 10-minute swap and it's gonna look awesome!
Honestly this thread needs more admiration of the white bronco badlands. My only concern is that bronze wheels will probably look better in black or even A51
I love the raptor wheelsI am not the first to mention this but I am curious how the bronco would look with the ranger raptor wheels. Same bolt pattern with 55 offset like the base badlands.
Did a quick photoshop with the Raptor Wheels. Pardon my fastback roof.I am not the first to mention this but I am curious how the bronco would look with the ranger raptor wheels. Same bolt pattern with 55 offset like the base badlands.
Thanks, How did you know that I order OW? I plan to change if green is available for MY22 and I like the shade. I may need to find a set of these wheels to mount dedicated snow tires on.Did a quick photoshop with the Raptor Wheels. Pardon my fastback roof.
With a 2.7, not necessary per se, but your gears will seem longer and won't quite come off the line like it would with the 4.7 gears. I ran 35s on 3.73 gears and it was a dog, but that was in a TJ. It wasn't till I went to 4.55 gears that it felt right.Is it absolutely necessary to upgrade the gearing on a stock Badlands to run 34 or 35 in tires?
I rather go stock and upgrade tires and wheels separately, and add the ford performance lift when it becomes available. The 35" Goodyear MTs in the Sas package look boring compared to the other options we saw at KOH.
