Bilstein 6100 on non sas badlands?
Paulj826
Nissan
Anyone know if the Bilstein 6100 work on the badlands non sas? Seen some posts saying you need the sas springs for this install and the stock won’t work.
PWillette
Parrie
Maine
I could be wrong but I do believe the SAS top hat and spring perch are different from the non-SAS which is why they won't work.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I have mixed and matched some Badlands and Sasquatch springs and they seem to be compatible. I have Sasquatch springs on standard BL shocks in the rear right now.
wkaotp
Sean
Portland, OR
Audi SQ5, Sprinter 4x4
I installed 6100 on my non-sas Badlands. No issues what so ever.
Paulj826
Nissan
Thanks for confirming , after reaching out to the supplier they confirmed they do fit as well. What’s your impression of The ride quality so far?
SnowBronco
Canada
6100's on my Badlands 2.7, non Sas on 35's! You may lose half in lift up front tho... Front and rear set to perch setting 5, highest setting. Mine still has a little rake. Maybe the front badlands springs are a bit softer? Either way they work and perform great!
Ford Bronco Bilstein 6100 on  non sas badlands? PSX_20230318_113008
Paulj826
Nissan
Looks great. Maybe they settled a bit. The fronts are 2.6 inches right at 5? What was total lift in front once installed? Would have thought the kit levels you out pretty good.
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 21 Bronco
So, why is it I can get all 4 6100s from rockauto for $875, but they are $1276 everywhere else? What am I missing? I know the part numbers are slightly different, but why?
Paulj826
Nissan
I see same part numbers on rock auto . Correct part numbers for badlands and SAS models are :
24-318594
24-318600
mrconns
CT
bmw x1, chevy suburban
the rear standard badlands springs are the same as the rear sasquatch springs already (same part#), so long as it is a 4-door and not a 2.3 auto w/o tow
